by KatieW » Tue Apr 21, 2020 2:10 pm
I want to retain the patina on my series 2 wheels, but any suggestions on what to paint the inside of the wheels with as I want to protect the inner tube and tyre when I put the wheels back together.
I have already cleaned the insides of rust and old paint.
KatieW
by Mel K » Tue Apr 21, 2020 3:00 pm
I would (and do ) Rattle can the inner Of the rims with any paint you have and rub them down and do them again each time you change the tyre and tube . As long as they’re smooth and free of corrosion any paint will do but I wouldn’t put it on too thick is all .
Mel K
by Toddy » Tue Apr 21, 2020 3:57 pm
Mel K wrote:I would (and do ) Rattle can the inner Of the rims with any paint you have and rub them down and do them again each time you change the tyre and tube . As long as they’re smooth and free of corrosion any paint will do but I wouldn’t put it on too thick is all .
+1
by Warkton Tornado No.1 » Thu Apr 23, 2020 9:53 am
Gulp!
Am I the only one that used to build old, rusty wheels by wire brushing off the loose stuff on the inside then a liberal application of grease to emulate tyre soap? Building a wheel in that manner always ensured easy dismantling & the tyre beads always wiped away excess grease to the outside in any case. Purely for precaution, I then used to wash down the (temporarily over) inflated tyre in a bowl prior to doing the washing up......
by John Deeley » Thu Apr 23, 2020 10:32 am
A good brushed on coat of smooth hammerite works well.
John Deeley
by bookertmgs1 » Thu Apr 23, 2020 11:55 am
John Deeley wrote:A good brushed on coat of smooth hammerite works well.
+ 1 on that.
Get inside the rim rust free and then hammerite. If its showing any signs of failing at next tyre change then quick rub down and blast with rattle can on the affected area
bookertmgs1
by solostax » Thu Apr 23, 2020 1:38 pm
solostax
by Warkton Tornado No.1 » Thu Apr 23, 2020 3:32 pm
I've got a humongous pile of ironing to do sometime. I bought a beer kit to do a year ago & still haven't brewed that! There's just not enough hours in the day, what with plucking the infestation of nose & ear hair that gets worse each day. It's all back breaking! My Lady has it easy, by comparison, just digging the garden over...
by dscscotty » Thu Apr 23, 2020 11:42 pm
Grease on wheel rims?
not advisable
Users browsing this forum: Google [Bot] and 75 guests
