Stub
Stub
Postby rossclark » Sun Mar 01, 2020 12:46 am
Anyone with direct experience know what the ID / OD of the RM Avanti Clubman stub/manifold is?
I'm currently on a v4 BGM - which I think is restricting the topend on my RT but like the advantage of the 4 stud fixing and wondered if you could keep the stub and change the pipe.
Re: Stub
Postby vegansydney » Sun Mar 01, 2020 6:44 am
Have you considered welding on one of these to your pipe of choice?
vegansydney
Re: Stub
Postby roli150lam » Sun Mar 01, 2020 8:38 am
Doesn't fit,not on my ts stub anyway.
O/D 44 I/D 43.3.is the measurement of my Avanti u bend.
roli150lam
Re: Stub
Postby rossclark » Sun Mar 01, 2020 2:20 pm
vegansydney wrote:Have you considered welding on one of these to your pipe of choice?
Good plan - thanks
Re: Stub
Postby rossclark » Sun Mar 01, 2020 2:22 pm
roli150lam wrote:Doesn't fit,not on my ts stub anyway.
I think the BGM stub is 42mm - will check it out thanks
Re: Stub
Postby rossclark » Fri Apr 10, 2020 11:55 pm
Doesn't fit on the BGM stub
Re: Stub
Postby dickie » Sat Apr 11, 2020 9:54 am
Bgm stub od is 42mm. Od of avanti stub is 41.5mm
Re: Stub
Postby bike grim » Sat Apr 11, 2020 1:18 pm
I’ve just tried a brand new BGM TS1 stub and its a nice snug fit on the avanti Exbox header. Both measure 41.5mm OD. You would have to chop 10mm of the actual length of the BGM stub for it fit as per the Exbox stub. Pm me an email address if you want me to send pics
Update* tried 2 BGM stubs for TS1. One fits as above, the other is 41.7mm and doesn’t fit (but could be made to) and the stub is actually 3mm shorter than the other BGM stub.
G
Users browsing this forum: Baidu [Spider] and 43 guests
