Under Panel Battery Tray, bolt to strut
Postby 69GP225 » Tue Apr 07, 2020 12:21 am
Does anyone know where I can buy the stainless steel battery tray that bolts to the rear strut?
Anyone fitted one?
Looking to buy one so I can fit a battery for a rev counter... thanks
69GP225
Re: Under Panel Battery Tray, bolt to strut
Postby HxPaul » Tue Apr 07, 2020 7:39 am
https://www.ebay.co.uk/itm/Lambretta-ST ... Swvg9XaRGQ I fitted one on a series 2.They dont make one for a series 2,so I had to drill another hole and put a different rear piece of steel on the back.
Postby landybretta » Tue Apr 07, 2020 9:21 am
More expensive but maybe safer. I speak from experience after my stainless steel one came loose (my fault). New hub required.
https://k2customs.co.uk/products/under- ... x-ser-3-gp
landybretta
Postby Knowledge » Tue Apr 07, 2020 12:05 pm
If you are using a gel battery, like the ones used in burglar alarms, then you get a much greater choice of shape and size and you can mount them at any angle (except inverted).
You might find something that can be hidden away in an existing toolbox. Yuasa are good, and have a pdf file available with all the dimensions quoted.
Just a thought.
Postby bike grim » Tue Apr 07, 2020 1:36 pm
Get a lithium ion battery. Light as a feather and maintenance free. You can mount them wherever you want 360 degrees and just a cable tie will hold in place
Postby 69GP225 » Tue Apr 07, 2020 5:23 pm
https://www.google.co.uk/amp/s/bilkosoi ... -tray/amp/
Thanks guys, got one of these just need the battery.
Looks neat !
Will see appreciate your help.
69GP225
Users browsing this forum: No registered users and 91 guests
