Clutch
Clutch
Postby Mick1499 » Tue Mar 24, 2020 11:17 pm
Ok boys your views please complete rebuild when trying to start can feel the clutch slightly engaging.slack clutch off starts fine then it’s not engaging enough when in gear ? It one or the other
Mick1499
Re: Clutch
Postby Knowledge » Mon Mar 30, 2020 9:01 am
Is this a standard four plate clutch as Innocenti intended, or an upgraded clutch?
Re: Clutch
Postby Mick1499 » Mon Mar 30, 2020 9:54 pm
Standard but has sirflex plates
Mick1499
Re: Clutch
Postby rossclark » Mon Mar 30, 2020 10:01 pm
There are some batches of 'Surflex' branded plates that are too thick - something like 15.5 mm for the four. They should be about 14 mm for the four cork plates. You can manage that out using thinner steels or top plates to allow more separation. Personally if you find they're some of these I'd get something else.
