TMX 30mm
TMX 30mm
Postby Psychedelicropcircle » Wed Mar 25, 2020 6:23 pm
Thinking of going with this carb, running a 195 imola (yes 195) v force reed with an expansion. Does anyone have a similar setup or can advise on jetting?
Scott.
Re: TMX 30mm
Postby Scooterdude » Wed Mar 25, 2020 6:34 pm
Yes contact Martin Corrado of Just Lambretta, he uses both TMX27 and tmx30 on imola.
Scooterdude
Re: TMX 30mm
Postby bike grim » Thu Mar 26, 2020 12:33 am
On a Quattrini 210 (218) with a CST10 curly using a varitronic ignition
Power jet 40
Main 320
Pilot jet 30 (feels rich)
Float valve 3.0
Needle 5-EL68 P3 (middle of 5)
Atomiser 622/2
Re: TMX 30mm
Postby Psychedelicropcircle » Thu Mar 26, 2020 7:55 am
bike grim wrote:On a Quattrini 210 (218) with a CST10 curly using a varitronic ignition
Power jet 40
Main 320
Float valve 3.0
Atomiser 622/2
Sounds like a cracking set up BG. I had an eye on the CS curly is it robust ?(most curlys aren’t) and does it give good power through the range? Have a jollymoto thing here which gives off a lovely ping but only gives power towards the top!
Scott
Re: TMX 30mm
Postby bike grim » Thu Mar 26, 2020 12:09 pm
Yep very good power. On 4.4:1 gearing it revs through nicely with loads of torque. Power kicks in at 5500 rpm but in top drops off about 7400 rpm (but that is 80 mph). Lots of torque “off” pipe. Bit loud though. I think it’s the Quattrini exhaust port that makes it loads louder than other kits not the actual pipe. I did have grounding issues but generally ok for solo riding. Well made and looks like a work of art.
Return to Carburettors
