Headset wiring
Headset wiring
Postby gizmo » Sun Mar 22, 2020 8:02 pm
I've got this written down but still confusing myself. 12V a/c. Mb loom, casa ignition. To horn I have white from light switch and red from loom. Ignition a brown has 2 feeds. What does the long one go to as it's long enough to go to horn. Also the purple. Does it go with red from loom. Thanks
gizmo
Re: Headset wiring
Postby Toddy » Mon Mar 23, 2020 1:12 pm
If the red from your loom is a power feed like Brown yes it will go to Horn , Most ignitions have a brown feed that goes to the horn as well so that can be capped off if you use the red from the loom , The purple from the ignition ? i believe bridges with the browns in the headlight block
Re: Headset wiring
Postby gizmo » Mon Mar 23, 2020 7:59 pm
Thanks Toddy, annoying thing is I've fitted 2 of these before but don't remember the long wire
gizmo
Users browsing this forum: Google [Bot] and 78 guests
