drivera wrote:If the slide is worn you might have a groove where the tick over screw sits which would make the slide sit lower , hence no tick over ?
Mickgrundy wrote:Hi all,
........The mixture screw is out by 2.5 turns per AR Rayspeed instructions.
coaster wrote:Mickgrundy wrote:Hi all,
2.5 turns, are you sure about that![]()
I thought most carbs should be arounf 3/4 out
if you are having to come out that far then maybe you pilot/idle jet is too small or blocked as Drivera mentioned.
Did you do a leak down test when you built the top end? air leaks are common and play havoc with trying to dial the carb in.
Mickgrundy wrote:Hi all, thanks for all of these replies.......What is a leak-down test and how do I perform one? Although thinking about it, if I had an air-leak surely this would give me a weaker mixture and I think the mixture is now OK?
Warkton Tornado No.1 wrote: The differences are in the small holes & their positioning in the atomiser sides for fuel pick up.
Users browsing this forum: No registered users and 32 guests
