Old skool ts1
Old skool ts1
Postby Scooterlam » Wed Mar 18, 2020 11:49 pm
Been wanting to build this for a while.
I've got a fresh plated early 70mm barrel.
Choice of 58 or 60 Crank.
107 or 110 rod.
Boysen or standard reeds.
30mm phbh or 34mm flat slide delly
Jl3, jl4, taffy copy NK Road or fresco
What would you do?
Scooterlam
Re: Old skool ts1
Postby ULC Soulagent » Thu Mar 19, 2020 2:15 am
60x110
Boysen
30 delly
NK Road
:D
ULC Soulagent
Re: Old skool ts1
Postby gaz_powell » Thu Mar 19, 2020 8:51 am
As AF intended.....standard kit, good 107 crank, Fresco and to get better economy a 30mm phbh - they do all you need in this form.
Ive ran 34 VHSB and taffy copy for years with no problem but heavy on juice so moving to 30mm carbs for this year....working on jetting at minute.
Just put a fresco on (ali end can) one bike and was pleasantly surprised on the test runs. The fresco runs on further than the taff copy but the taff copy is a more civilised ride
I stub mounted the fresco u bend
So im running this year standard kits with taffy copy and another with fresco
Re: Old skool ts1
Postby Simon ELC » Fri Mar 20, 2020 10:13 pm
64x118
Yamaha reeds
VHSH 30
NK Road all day (Ron Moss clubman works well if you like standard looks)
5 speed box
Simon ELC
Re: Old skool ts1
Postby dscscotty » Sat Mar 21, 2020 1:08 am
to get port timings usable 64x118 would require considerable work
Re: Old skool ts1
Postby gaz_powell » Sat Mar 21, 2020 9:04 am
True Old skool would be a mazzachelli 107 crank, standard kit, Amal Mk 2, fresco, standard 4 plate clutch with a centre spring, GP gearing and 19/46 sprokets.....
You can to rocket to over 90mph on that set up.........well you could back then allegedly but I think that's with a 10 quid Indian 120mph speedo.....
Re: Old skool ts1
Postby Vega125s » Sat Mar 21, 2020 8:15 pm
I guess I’m still running old school, my GP.
34 years on!
TS200
Second piston ,
Michec exhaust (absolutely terrible)
Now bgm box
Still going strong
Vega125s
Re: Old skool ts1
Postby gaz_powell » Sun Mar 22, 2020 11:50 am
Vega125s wrote:I guess I’m still running old school, my GP.
34 years on!
TS200
Second piston ,
Now bgm box
Still going strong
I like to hear things like that!
Re: Old skool ts1
Postby martyn dwane » Sun Mar 22, 2020 2:29 pm
Running a TS1200, Yamaha IT175 piston, 58mm /115mm RD400 rod, with 30mm Amal and Mikec MK5 or 6 cant remember which, think the barrell is No 66 or somewhere near that,.
martyn dwane
Re: Old skool ts1
Postby Scooterlam » Tue Mar 24, 2020 12:09 pm
Ive got a rayspeed S type 1988
Ts1 200
34mm Amal
Midland scoot exhaust.
Af light flywheel
12v DC.
Got a woosner piston as 2 assos failed.
I should have said Old Skool tuned ts1
Scooterlam
Re: Old skool ts1
Postby Simon ELC » Tue Mar 24, 2020 9:46 pm
dscscotty wrote:to get port timings usable 64x118 would require considerable work
Yeah, a bit. 5mm of weld added to the top of the barrel.
Simon ELC
Re: Old skool ts1
Postby gaz_powell » Fri Mar 27, 2020 6:14 pm
That's not very "old skool"...…
Re: Old skool ts1
Postby Norrie Bodge » Sat Mar 28, 2020 4:30 pm
ULC Soulagent wrote:60x110
Boysen
30 delly
NK Road
:D
What casings is this on m8? & with what base packer??
Also is it a torqueey thing or is it all top-end ?
You don’t mention your gearing too
Norrie Bodge
Re: Old skool ts1
Postby ULC Soulagent » Sat Mar 28, 2020 6:59 pm
Boysen
30 delly
NK Road
:D
Jet200 casing Matched to Ts1
Mb tuned TORQUE TOUR TUNE with 3mm base packer
Bgm clubman modified
Sx200 gearing 15x46 although I could use a 16 also.
I normally use a 25 delly on it for loads more torque over bhp
Putting on the 30 ups the gains big time both on bhp & Torque
ULC Soulagent
Re: Old skool ts1
Postby Vega125s » Sun Mar 29, 2020 6:04 pm
So great to hear there are a few TS 200 still going!
martyn dwane , could never get mine to rev out all those years ago with a Michec exhaust , great acceleration but topped out at 50! Used an old PM for years then and still using a BGM V1 which is great.
Vega125s
Re: Old skool ts1
Postby Norrie Bodge » Mon Mar 30, 2020 7:58 am
Boysen
30 delly
NK Road
:D
I thought you said NK road pipe?
That’s why I was asking of your full setup m8
Norrie Bodge
Re: Old skool ts1
Postby ULC Soulagent » Mon Mar 30, 2020 2:51 pm
It did but I don’t like expansion pipes so changed it for a modified Bgm as I like the standard looks ;)
ULC Soulagent
Re: Old skool ts1
Postby Ralph95 » Thu Apr 23, 2020 11:44 pm
Old school TS1 225 port to Taffspeed spec use early indian head ,34mm amal and a mk 6 Mikec Exhaust in it's day a rocket :D built a few when I Worked at taffspeed in 88 ;)
Ralph95
Re: Old skool ts1
Postby Scooterlam » Sun Apr 26, 2020 3:34 pm
My ts1 200
Gpsd at 75.ph on the same day and road as about 10 other scoots.
Well in the top 1/3rd
Beat some more modern kits and tunes.
Scooterlam
Re: Old skool ts1
Postby gaz_powell » Sun Apr 26, 2020 4:39 pm
/\/\ I like that !!!
