Which clubman.
Which clubman.
Postby St George » Tue Mar 17, 2020 6:38 pm
I have a LI150 Engine with a new alloy 185 kit fitted. Tried my mates clubman and it ran fine but the exhaust system would not line up, not even close.. Has anyone had success with any other clubmans that would fit this set up. Also running 30 mm Delly. Thanks...
St George
Re: Which clubman.
Postby ULC Soulagent » Tue Mar 17, 2020 7:26 pm
It ur wanting a clubman with flexibility built in then it’s gonna be the Bgm, unfortunately you take a risk from the others with have fixed mounting points as you know nothing ever fits properly these days without some modifications :D
ULC Soulagent
Re: Which clubman.
Postby gaz_powell » Tue Mar 17, 2020 8:06 pm
I found the scootopia one a good fit and works well on stage 4 200.
Good value
Re: Which clubman.
Postby al pushpak » Tue Mar 17, 2020 8:37 pm
Bgm, Scootopia both good, also the Ron Moss super clubman is a good choice, got one on both my Ts1's ;)
al pushpak
Re: Which clubman.
Postby Toddy » Tue Mar 17, 2020 8:54 pm
Agree re the scootopia great fit , heard good things about the Ron moss re fit and performance as well
Re: Which clubman.
Postby bike grim » Tue Mar 17, 2020 9:05 pm
Just fitted a Ron Moss Ex-box, very good fit and very good performance. His next batch is due next month I believe
Re: Which clubman.
Postby Lammer205 » Tue Mar 17, 2020 9:49 pm
I would like to see back to back dyno runs with the Bgm and RM Exbox on a TS, I have heard conflicting reports. Lammer205
Lammer205
Re: Which clubman.
Postby Kev Fox » Tue Mar 17, 2020 11:47 pm
Fitted a few BGM Clubman ver 4. All fitted perfectly and standing up well.
Kev Fox
Re: Which clubman.
Postby bike grim » Wed Mar 18, 2020 12:54 am
Lammer205 wrote:I would like to see back to back dyno runs with the Bgm and RM Exbox on a TS, I have heard conflicting reports. Lammer205
If you’re on FB join the Lambretta Supertune Rallye SE page as there are some dyno sheets on there showing what you want
Re: Which clubman.
Postby Rich Oswald » Wed Mar 18, 2020 1:48 pm
Toddy wrote:Agree re the scootopia great fit , heard good things about the Ron moss re fit and performance as well
Soon know as Ron is just invoicing me for mine from the new batch to be sent out first week in April.
Kev Fox wrote:Fitted a few BGM Clubman ver 4. All fitted perfectly and standing up well.
Heard tha BGM V4 is lacking in performance now that they have quietened them a bit. I have a V1 and V3 and both are good though.
Re: Which clubman.
Postby dickie » Wed Mar 18, 2020 4:31 pm
my V3 keeps falling to bits. good performance but the baffles fell to bits. The silencer cracked in several places. It's been cut and welded more times than a 90s cut and shut XR2.
Re: Which clubman.
Postby rossclark » Sat Mar 21, 2020 11:53 pm
Ditto on all points.
I have the V4 on my RT and it won't roll on much beyond 6800 in top.
Re: Which clubman.
Postby bookertmgs1 » Mon Mar 30, 2020 7:02 pm
the V4 has definately taken away some of the torque at midrange but has put something on the top end.
My V3 was replaced under warrenty - but given the chance I'd swap back and get my V3 fixed.
The "improvements" they made to quieten the sound have affected my RT kit. Previoulsy was able to fly up hills without any change down - now its a constant gear changes to keep the momentum going. On the plus side - the improvment in top end speed is welcolme when doing motorway miles.
If I could pick up a V3 - then I'd be swapping exhausts to suit the journey - seems excessive - but the tourque on country roads makes a significant difference to the grin factor
bookertmgs1
Re: Which clubman.
Postby Rich Oswald » Tue Mar 31, 2020 8:21 am
Talking to two very well known tuners, there are gassing up problems now with V4, which restricts the revs and can lead to seizures.
Re: Which clubman.
Postby ULC Soulagent » Tue Mar 31, 2020 8:40 am
bookertmgs1 wrote:the V4 has definately taken away some of the torque at midrange but has put something on the top end.
Strange, my V4 unmodifed version gained bottom n midrange but lost out at top end :shock: on my Rt200
ULC Soulagent
Re: Which clubman.
Postby ULC Soulagent » Tue Mar 31, 2020 8:42 am
Rich Oswald wrote:Talking to two very well known tuners, there are gassing up problems now with V4, which restricts the revs and can lead to seizures.
Rich, I take it that’s from large CC engines 225 and above ?
ULC Soulagent
Re: Which clubman.
Postby Rich Oswald » Tue Mar 31, 2020 10:41 am
Yes mate, sorry forgot to say that.
Re: Which clubman.
Postby bamrattle » Sat Apr 04, 2020 7:06 am
The ron moss 1 will probably outlast a bgm 1 they just fall apart
bamrattle
Re: Which clubman.
Postby Rich Oswald » Sat Apr 04, 2020 10:24 am
bamrattle wrote:The ron moss 1 will probably outlast a bgm 1 they just fall apart
Ha ha, bloody hell who rattled your cage. Where ya been Trev'?
Re: Which clubman.
Postby Toddy » Sat Apr 04, 2020 8:12 pm
Isolation ;)
Users browsing this forum: Baidu [Spider] and 74 guests
