Throttle return spring
Postby gizmo » Sat Mar 14, 2020 2:49 pm
Is there an easy way to get a throttle return spring on. I have got to point saying I've managed for years without one but at least I tried :lol:
gizmo
Re: Throttle return spring
Postby dscscotty » Sun Mar 15, 2020 8:45 am
Postby gizmo » Sun Mar 15, 2020 10:00 am
dscscotty wrote:JPP Do a good return spring set
https://www.freewebstore.org/jpp-lambre ... rch=spring
I have the above mentioned dscscotty but trying to get the spring into the hole in the rod is a blooming nightmare. You have to somehow try and get the spring end in which faces opposite way and not being the most patient person is awkward to say the least. Deep breaths count to ten
gizmo
Postby Warkton Tornado No.1 » Sun Mar 15, 2020 1:08 pm
Now that I understand what you are on about:
http://www.scooterrestorations.com/lamb ... eta-n.o.s/
Personally, I find it as easy to make my own from a conventional tension spring that will fit the rod & shape the ends to suit. With a drilled hole through the rod, I use the eye of a split pin to act as the 'anchor' then fit the assembly (pre-wound) without the pulley to achieve some tension. Then fit the pulley (usually a gear change pulley with larger carbs)
In other words, fit the spring & rod assembly without the pulley. Wind in some tension. Then fit the pulley.
I hope that helps :)
Postby shane BBoys » Sun Mar 15, 2020 11:59 pm
Has any body used 1 of these on a series 2? ( not quick action )
shane BBoys
Postby coaster » Mon Mar 16, 2020 10:03 am
Self closing throttles are mandatory for competition use but make it impossible to do a right turn handsignal :? I strive to keep my throttle from self closing, usually by wrapping an elastic band into the gap between the grip. Not a problem I guess if you dont use hand signals :?
Innocenti didn't fi self closing assist springs but the Spanish did on their scooters fitted with indicators.
Postby HxPaul » Mon Mar 16, 2020 10:39 am
coaster wrote:Self closing throttles are mandatory for competition use but make it impossible to do a right turn handsignal :? I strive to keep my throttle from self closing, usually by wrapping an elastic band into the gap between the grip. Not a problem I guess if you dont use hand signals :?
Especially when you're going uphill and you want turn right,the throttle shuts off as soon as you take your hand off and put your right arm out.
Postby Warkton Tornado No.1 » Mon Mar 16, 2020 10:50 am
You can have a self closing throttle that is set up with good carburation to include a tick over, even with a very light flywheel ;)
