Poor cold starting RT 195
Postby Watto66 » Thu Mar 12, 2020 1:10 pm
Hello looking for a bit of advice . Apologies if this has been covered
Purchased a GP last year fitted with an RT 195 , 28 dellortto with foam filter ,BGM clubman ( new fitted by me ) new BGM stator flywheel and CDI engine was rebuilt by previous owner who's had lambretta s for years . I'm getting very poor starting when cold if left for a few days it takes multiple kicks ,choke appear to be operating freely , carb was rebuilt ,new plugs etc . When scoot is used daily its not to bad ad performance is ok ,not a missile but quick enough to commute which is what I used it for. I have borrowed a compression test dial gauge because I'm beginning to think it may be a worn ring/cylinder issue I cant seem to find what the reading should be for 195cc in PSI ?
many thanks
Watto66
Re: Poor cold starting RT 195
Postby ULC Soulagent » Thu Mar 12, 2020 1:49 pm
Try it with the foam filter off and see how u get on
ULC Soulagent
Postby Watto66 » Thu Mar 12, 2020 1:59 pm
Thanks think I tried that last previously ill try again
Watto66
Postby Rich Oswald » Thu Mar 12, 2020 4:43 pm
Could be something as simple as plug gap, don't mean to insult your intelligence though.
Postby MickYork » Thu Mar 12, 2020 6:34 pm
What type of carb and size of choke jet ?
Compression tests are ok but probably better to strip down, have a look and take some measurements…...who knows what sort of life it's had :?
Postby missing lynx » Thu Mar 12, 2020 7:02 pm
When was the last time you cleaned your filter and is it one that requires oiling?
Postby Andyf » Fri Mar 13, 2020 9:03 am
Was the new Clubman a like-for-like replacement?
Andyf
Users browsing this forum: al pushpak and 197 guests
