23 mm dellorto question
Postby mickey c » Fri Feb 28, 2020 8:04 am
Now i think the help on here has sorted my electrics I can try to get my scooter running.
The carb however was seized solid and the slide & needle knackered!
Will this fit my standard TV2 carb even though it’s for a different scooter?
https://rover.ebay.com/rover/0/0/0?mpre ... 3887250095
If not, where could I get one from?
Also which needle do I need & who / where would you suggest I get it?
mickey c
Re: 23 mm dellorto question
Postby ULC Soulagent » Fri Feb 28, 2020 9:22 am
Short answer is no :roll:
Getting parts for the Mb23 is nigh on impossible bar gaskets n jets.
A complete unit sometimes appears on flebay but go for silly money.
Best bet is throw the carb into a bucket of diesel/ kerosene and let it soak for ages.
In the meantime go buy a spaco reproduction as a get by although smaller 19mm from a reputable dealer. ;)
ULC Soulagent
Postby HxPaul » Fri Feb 28, 2020 11:43 am
Postby mickey c » Fri Feb 28, 2020 4:29 pm
Thanks guys, I have soaked & cleaned the carb. The issue was that I mangled the slide when trying to unseize it! Given how much a new carb is, I’ll try to file / smooth it into shape & see if it works. If not, I’ll have to buy a new 1.
mickey c
Return to Carburettors
Users browsing this forum: Google [Bot] and 55 guests
