AF 5 speed box
AF 5 speed box
Postby Stesjh » Sat Feb 22, 2020 7:53 pm
After some advice, recently had a AF 5 speed box fitted. Runs fine and all gears select fine. However, noticed a noise when in neutral. Have had it checked and everything appears fine and no sign of of any damage. Been put back together and still runs fine but still has a strange “whirling “ noise in neutral. Have read elsewhere that this is sometimes the case but wondering if anyone else has come across this?
Stesjh
Re: AF 5 speed box
Postby gerryjunior » Sat Feb 22, 2020 10:05 pm
id look at the clutch or chain or kickstart gear rubbing, gearbox isnt likely to make noise in nuetral
gerryjunior
Re: AF 5 speed box
Postby Scooterdude » Sun Feb 23, 2020 8:09 am
Does the noise change or disappear if you’re in neutral and then pull the clutch in?
Scooterdude
Re: AF 5 speed box
Postby Covboy » Sun Feb 23, 2020 9:22 am
I had this on a standard gearbox once. - had it apart many times changed bearings , chain checked everything over and over again - could never cure it so just lived with it. Only happened when hot.
Re: AF 5 speed box
Postby Stesjh » Sun Feb 23, 2020 1:28 pm
To be fair mine only seems to make a noise when warmed up. I have heard that some of the Rimini ones have a similar noise. Perhaps one more strip down to double check.
Stesjh
