MIRROR OPTIONS
Re: MIRROR OPTIONS
Postby Scooterdude » Thu Feb 20, 2020 9:54 am
I bought a handle bar mounted mirror from ms classic scooters, now this one fitter through the front brake lever pivot bolt hole but instead of having a properly machined fixture like the Lambretta restore one this had an m6 or m5 allen bolt which meant the lever flopped about, on top of this the mirror was in my opinion far to close to the front brake lever meaning that if you grabbed for the brake it was likely that your hand/fingers hit the mirror stem! I took it back off and sent it back. Bought a Stadium legshield mirror and after a bit of faffing about to get it right I’m happy with it.
Scooterdude
Re: MIRROR OPTIONS
Postby HxPaul » Thu Feb 20, 2020 10:45 am
Re: MIRROR OPTIONS
Postby Rob Miller » Thu Feb 20, 2020 10:49 am
Has anyone fitted one successfully to a series 2?
Rob Miller
Re: MIRROR OPTIONS
Postby Scooterdude » Thu Feb 20, 2020 3:04 pm
These are the shit ones I mentioned above, if you need to brake in a hurry it’s quite likely you will catch your fingers on the mirror stem rather than grab the lever.
Scooterdude
Re: MIRROR OPTIONS
Postby davej » Fri Feb 21, 2020 8:27 am
Best Stadium Mirrors come from Halcyon, Bit expensive unless you can team up and buy a bigger quantity
davej
Re: MIRROR OPTIONS
Postby HxPaul » Fri Feb 21, 2020 9:16 am
I can pull my front brake on ok.
Users browsing this forum: Google [Bot] and 173 guests
