SX200, TV200 + LI150 bitsa
Re: SX200, TV200 + LI150 bitsa
Postby johnnyfartpants » Mon Feb 03, 2020 11:21 am
Front hub was built up yesterday - really pleased that I didn't mark the paint!
Forks next - not looking forward to it!
johnnyfartpants
Postby johnnyfartpants » Mon Feb 03, 2020 3:50 pm
Forks now built up and ready to go. As is normal, it was a bit of a faff, but got there in the end without doing any damage.
johnnyfartpants
Postby johnnyfartpants » Fri Feb 07, 2020 6:41 pm
A little more time was found for this today - petrol tank, tap and air box all found their way back on to the frame.
When fully tightened, the straps were still slightly slack. This was remedied later on with larger rubber buffers.
johnnyfartpants
Postby johnnyfartpants » Sat Feb 08, 2020 5:28 pm
Forks and handlebars now in position, I need to order in some more parts before I can get much further.
johnnyfartpants
Postby shane BBoys » Sun Feb 09, 2020 7:17 am
Looking good, I don’t see any cables I guess these are the bits that you need to order, will you manage to route them alright?
Cheers Shane.
shane BBoys
Postby johnnyfartpants » Wed Feb 12, 2020 9:26 pm
shane BBoys wrote:Looking good, I don’t see any cables I guess these are the bits that you need to order, will you manage to route them alright?
Cheers Shane.
Cheers! Shouldn't be a problem routing the cables - I always build my Lambrettas this way!
Grabbed a bit of time after a job interview today - wheels and hubs were built up with new tyres + tubes.
Then the dampers were sprayed up after being bare metalled yesterday.
I'll hopefully be getting the motor in at some point in the next couple of weeks. :)
johnnyfartpants
Postby johnnyfartpants » Sun Feb 16, 2020 8:47 pm
Smartened up a few pieces after stripping them back to bare metal.
Made a start cleaning up the engine too. I'd originally planned a complete strip and rebuild, but theres nothing wrong with it, so a clean and spruce up will be fine for now. (gonna replace the carburettor though, the one on it is problematic)
Whilst stripping parts off to ease the cleaning process, I noticed that the gear shift tie rod was worn, giving a sloppy gear change. The elongated hole was welded up and re drilled, which should reduce the travel of the handlebar considerably during shifts.
Totally regret scrapping the frame that this engine came to me in - would have been an easy fix for me nowadays!
johnnyfartpants
Postby johnnyfartpants » Sun Feb 16, 2020 8:49 pm
Cables now ordered, as well as rubber trim + floor stuff! :D
johnnyfartpants
Postby johnnyfartpants » Fri Feb 28, 2020 5:58 pm
Start my new job on Monday. 8-) Its a lot less pay than my last one, but I reckon I can manage it.
Indoor job done today (far too cold in the garage) Number plate was stripped of paint.
Masked up, primed, sprayed and buffed up.
Should hopefully be getting cracking with this soon. :D
johnnyfartpants
Postby Knowledge » Sat Feb 29, 2020 3:19 pm
Good luck with the new job JFP, and keep posting those updates on the scooter. :D
Postby johnnyfartpants » Fri Mar 06, 2020 9:33 pm
Knowledge wrote:Good luck with the new job JFP, and keep posting those updates on the scooter. :D
Many thanks! Updates should be coming a bit quicker now. 8-)
Motor now cleaned up ready to go back in - just need to switch the carburettor.
Dived into the big box of new bits from Scootopia, and got a few more pieces fitted. Hopefully be getting the motor back in and cabled up over the weekend.
johnnyfartpants
Postby johnnyfartpants » Sat Mar 07, 2020 11:15 pm
Got my polishing head on this afternoon, and smartened up the brake and clutch levers. They were a bit of a mess with lots of oxidisation, but cleaned up pretty well.
Finally got my act together and stuck the motor in this evening.
Exhaust went back on before going for a pint.
johnnyfartpants
Postby johnnyfartpants » Sat Mar 07, 2020 11:17 pm
Cables and wiring up next, should be making a start on that at some point tomorrow. :)
johnnyfartpants
Postby johnnyfartpants » Sun Mar 08, 2020 9:04 pm
Cables now roughly in position, I've ordered new trunnions for the gear + clutch cables, and new brake cable clamp/adjusters. I'll finalise the position of the cables once they're all buttoned up and adjusted.
The wiring is pretty much sorted, I just need to tidy up the routing above the rear mudguard once the regulator has been mounted.
Looking forward to getting the bodywork back on at some point!  :)
johnnyfartpants
Postby johnnyfartpants » Sat Mar 14, 2020 9:59 pm
Cables now done up and sorted, wiring wired, and lights lit. Many thanks to Martyn for the wiring diagram. 8-)
Should get it running next week, then it's bodywork + trim time. :P
johnnyfartpants
Postby dickie » Sun Mar 15, 2020 10:20 am
johnnyfartpants wrote:Cables now roughly in position, I've ordered new trunnions for the gear + clutch cables, and new brake cable clamp/adjusters. I'll finalise the position of the cables once they're all buttoned up and adjusted.
I've always tried to keep my cable routing and cable ties as per original but on my last build Martin cook (chiselspeed) advised me to use none on the clutch cable. When I look at my triumph 1050, it has none at all in the clutch cable, so it just finds it's own way. And when I think about it, all my big bikes have been like that.
I did this on my last build and it's a revelation. So much lighter than others I've done with same 5 plate and bgm spring set up.
I did think the cable might have hung out hither and thither looking a mess, but it doesn't.
Postby johnnyfartpants » Sun Mar 15, 2020 10:17 pm
Sounds perfectly reasonable - I'll set it free before the legshield goes on. :)
johnnyfartpants
Postby Storkfoot » Mon Mar 16, 2020 12:44 am
Thanks. I think I’ll give this a whirl too on my next build. I have thought about it before but never done it.
Postby coaster » Mon Mar 16, 2020 10:12 am
Good call, when you think abaout it its only the gear cables and throttl that need securing on the stem to stop them falling down when changing cable inners.
Postby dickie » Mon Mar 16, 2020 3:26 pm
Actually, when you think about it, I'm not convinced you need any cable ties at all.
In fact when I build my next one I'm going to try to leave them off completely. A bit of insulating tape for the build phase then take it off when I'm finished. If I need to replace a cable inner, a temporary cable tie or someone to hold the outer in place will suffice...I think.
Although as it's a straight run down the steering tube, you're probably right and it's worthwhile just one tie there.
Users browsing this forum: No registered users and 253 guests
