AF electronic DC wiring
Postby johnnyfartpants » Mon Feb 10, 2020 2:57 pm
How do!
I'm part way through rebuilding a lambretta, and I've lost the wiring diagram that was supplied with my electronic kit (almost 30 years ago!) Does anyone have a copy of the DC diagram? I can only find the AC diagram online. :roll:
Cheers, Steve
johnnyfartpants
Re: AF electronic DC wiring
Postby ULC Soulagent » Mon Feb 10, 2020 4:19 pm
Is there not one in Sticky’s Bible ?
ULC Soulagent
Postby ULC Soulagent » Mon Feb 10, 2020 4:24 pm
ULC Soulagent
Postby johnnyfartpants » Mon Feb 10, 2020 8:25 pm
Does the regulator not need to be earthed then? Most regulators seem to have a terminal marked with a ground symbol.
My regulator that came with the kit is marked 343152 with terminals marked G G R B+ C ( R and B+ terminals joined together)
From the diagram in Sticky's manual, my regulator has its terminals in a different position - obviously the battery must go to B+ but where does the brown wire go to (R or C)
In case nobody had noticed, electrical stuff is not my best subject! :lol:
johnnyfartpants
Postby ULC Soulagent » Tue Feb 11, 2020 11:26 am
johnnyfartpants wrote:Does the regulator not need to be earthed then? Most regulators seem to have a terminal marked with a ground symbol.
Neither is mine so it could be the blind leading the blind :lol:
ULC Soulagent
Postby martyn dwane » Tue Feb 11, 2020 2:47 pm
Cheers, Steve[/quote]
is this an originally AF elecronic from the late 80`s ? are there two seperate sleeved groupes of wires coming from the staor /?
if it is i have the diagram at home .
martyn dwane
Postby johnnyfartpants » Tue Feb 11, 2020 4:51 pm
martyn dwane wrote:I'm part way through rebuilding a lambretta, and I've lost the wiring diagram that was supplied with my electronic kit (almost 30 years ago!) Does anyone have a copy of the DC diagram? I can only find the AC diagram online. :roll:
Cheers, Steve
if it is i have the diagram at home .[/quote]
It is! That would be most helpful. I've only recently lost mine - it'll probably turn up once it's all finished!
johnnyfartpants
Postby ULC Soulagent » Tue Feb 11, 2020 5:06 pm
Would this be the regulator that you are using
ULC Soulagent
Postby johnnyfartpants » Tue Feb 11, 2020 5:14 pm
Its a Ducati one marked 343152
johnnyfartpants
Postby martyn dwane » Sun Feb 16, 2020 7:32 pm
martyn dwane
hope it helps.
martyn dwane
Postby johnnyfartpants » Sun Feb 16, 2020 8:41 pm
martyn dwane wrote:hope it helps.
Thank you very kindly! Thats the same diagram that I've mislaid. :)
johnnyfartpants
Postby martyn dwane » Mon Feb 17, 2020 2:47 pm
i seem to remember , my battery used to go flat after a few days if i didn`t use it, even with the switch fitted from Reg to junction box, but it was along time and ive been asleep since then :lol: :lol:
martyn dwane
Postby johnnyfartpants » Mon Feb 17, 2020 8:32 pm
martyn dwane wrote:i seem to remember , my battery used to go flat after a few days if i didn`t use it, even with the switch fitted from Reg to junction box, but it was along time and ive been asleep since then :lol: :lol:
Aye, this one did the same (maybe took a couple of weeks) Just took the neg off the battery if I knew it would be a while until the next ride. 8-)
johnnyfartpants
Postby missing lynx » Mon Feb 17, 2020 8:43 pm
I put a isolating switch on my battery otherwise it went flat
Users browsing this forum: No registered users and 138 guests
