Rich Oswald wrote:Really does sound like the choke but you have checked as you say. Are you sure it is not lifting due to a tight cable when you are sat on the scooter?
Fast n Furious wrote:It does sound like it has developed the dreaded stator made rev limiter!
ROClarke wrote:Head Gasket ?
St George wrote:Mine revs out on the stand fine, dies on load. Carb triple checked ?
Martin s wrote:Thanks for the excellent replies, only just been able to work on it. Swapped the usual stator, cdi, reg and spark plug.It's obviously jetting.
Changed the atomiser to av 264 with the same x7 but is only rideable with clip in top position. Done a few miles, now intermittent cutout with no spark, then starts again. Hoping to get a casa ignition at the weekend, had enough of
the indians now. Does it need to be run in to put it on a dyno? Not done any plug chops yet, but not confident on the
jetting. Hoping to get to Dorset on it next week!
Users browsing this forum: No registered users and 84 guests
