pinprick airleak in barrel wall
Postby Psychedelicropcircle » Sun Feb 02, 2020 5:27 pm
how do you go about fixing this? This started out life as a 186 imola, I managed to kill it so bad it was bored out to a 195 ceramic lined & im building this only to find an airleak in the barrel wall! bought in 2010 so I doubt it was here before its rebore! bad casting?
Re: pinprick airleak in barrel wall
Postby missing lynx » Sun Feb 02, 2020 5:59 pm
Shouldn't the ceramic coating be air tight?
Postby missing lynx » Sun Feb 02, 2020 6:01 pm
Looking at it isn't it where the transfer ports are?
Postby Knowledge » Sun Feb 02, 2020 8:16 pm
Yes, that is on the transfer wall: the ceramic treatment would not have touched it.
I would just put some Araldite over it. My barrel is full of such fixes.
Postby sunrisemac » Sun Feb 02, 2020 8:22 pm
we use a company Ultraseal based in Slough to seal our ally cylinder heads and anything else that has porosity that would cause a problem.
http://ultrasealslough.co.uk/
sunrisemac
Postby Scooterdude » Sun Feb 02, 2020 9:26 pm
You can buy low temperature alloy “welding rods” that melt using a regular blow torch that would be my choice for repair.
Scooterdude
Postby dickie » Sun Feb 02, 2020 9:52 pm
Scooterdude wrote:You can buy low temperature alloy “welding rods” that melt using a regular blow torch that would be my choice for repair.
Maybe I bought poor quality ones, but mine just crumbled rather than melt.
Postby Warkton Tornado No.1 » Sun Feb 02, 2020 10:21 pm
Blimey!
If it's transfer wall, why not just drill the hole bigger, tap to something like M3 & Loctite a good screw in place? I'd use A4 stainless & finish both sides flush for an almost invinsible repair.
Postby Knowledge » Mon Feb 03, 2020 12:09 am
Have noticed that when they show people using that low temp Ali welding rod, they are welding Coke cans, not big lumps of Ali, like an engine barrel? You just can’t get enough heat into the barrel to get the process to work, especially as the barrel is purposely designed to disperse heat.
These rods have their place, but not here.
Postby Fast n Furious » Mon Feb 03, 2020 12:36 am
+1
Postby Scooterdude » Mon Feb 03, 2020 10:21 am
Well rather than speculate would it not be a better idea to buy a single rod (as i did) and give it a try? If it works well fantastic, if it doesn’t well get someone to weld it properly with a tig.
Remember the low temp rods are not anything to do with welding, their more like a form of brazing so in this case should flow into any porosity that’s present.
Scooterdude
Postby dscscotty » Mon Feb 03, 2020 11:59 am
JB Weld it, done loads, this is more common than you think, but good chemical metal, such as JB weld will sort it,
Postby Psychedelicropcircle » Mon Feb 03, 2020 10:05 pm
Thanks for input lads, I’ll give the JB weld a go, stripped out the reed block twice thought I was going mad! Wasn’t until I located a breeze whilst trying to locate the hiss :o
Postby dscscotty » Tue Feb 04, 2020 1:27 am
JB Weld sorted this out! :shock:
Postby holty » Tue Feb 04, 2020 10:01 am
yes ive had one the same, remove cylinder and mark the hole in the transfer port in the inside and then clean with solvent then use some jb weld to seal the hole, problem solved
holty
Postby tonytoolbox » Tue Feb 04, 2020 8:13 pm
had the same on my imola tiny casting hole in the transfer ,used yambond , 5 euro's done and still all good
tonytoolbox
Postby Adam_Winstone » Wed Feb 05, 2020 11:39 am
Good timing as I need to do the same on my current build.
Question please: Which of the various JB Weld products are people using? The common 2 tube epoxy or the different high temp putty product?
Thanks in advance as knowing may stop me from trying the wrong stuff.
Adam
Postby dscscotty » Wed Feb 05, 2020 5:28 pm
I used just the standard tube stuff,
https://www.ebay.co.uk/p/24033516626?ii ... gIIUvD_BwE
Postby Bilko » Wed Feb 05, 2020 8:24 pm
I had one on my RT. The 2 tube version is what I used.
Bilko
Postby Adam_Winstone » Wed Feb 05, 2020 9:39 pm
Thanks for the replies guys. Ordered :)
