Nissin caliper rebuild kits
Postby NorthernJordan » Fri Jan 17, 2020 4:06 pm
Can anyone point me in the direction for the best place to buy a nissin 2 pot caliper rebuild kit? Including the pistons? Also need a kit for the mater cylinder with sight glass ideally.
Cheers!
NorthernJordan
Re: Nissin caliper rebuild kits
Postby dickie » Fri Jan 17, 2020 6:06 pm
These are the same calipers as used on Honda cbr600f, the early steel frame type, built until about 1997.
Loads of bikes used them, but that must be the most common.
Should be easy to find on Ebay etc
Postby missing lynx » Fri Jan 17, 2020 6:46 pm
When searching on e bay don't put Lambretta in search or you will pay over the odds!!
Postby Rich Oswald » Sat Jan 18, 2020 12:38 pm
Got mt master cylinder kit from Martin (Corrado) at just Lambretta but it was a while back.
Postby phil23fair » Fri Jan 24, 2020 10:09 pm
Search AB4861 on Wemoto.com, you’ll get a single piston and the seals, they also do a kit with both pistons and seals plus the caliper guide rubbers, bleed nipple, banjo washers and red rubber grease that is about an extra fiver than going down just the piston and seals route. I’ve just rebuilt two calipers using their kits and the pistons are stainless steel so if I ever have to do it again I’ll only need the seals
phil23fair
Postby Meds » Sun Jan 26, 2020 2:35 pm
I’ve been digging around on wemoto and it looks like the caliper kit that will match best is from a CG125f/GLR 125
The piston fitted to mine is 27mm long - which matches the piston in the GG 125 kit- the Rebel and CBR pistons are 31mm
The individual seal kits are AB0921 - which is the same for the Honda CMX 250 rebel mentioned un lambretta club USA website and the CBR600F 1995 as above
Can someone correct me if I’m wrong?
Meds
Postby phil23fair » Sun Jan 26, 2020 8:39 pm
The complete kit for a 27mm long x 25.2mm diameter piston is AG2184. It’s the kit for a Honda CBR 125 R4 (JC34) (04). I’ve just checked and you’re right the seal kit is AB0921
phil23fair
Users browsing this forum: Baidu [Spider] and 41 guests
