Kick start conundrum
Postby kevinneil » Sat Jan 11, 2020 2:04 pm
Hi I have a problem with kickstart on series 2 LI150
The kickstart seems to have seized e.g. won’t kick down. I took the chain case off and all seems to be OK. All the gear cogs turn and when removed you can depress the kick start fully.
Put back on without fastening properly and you can depress the kick start and it turns the engine over.
Now I fasten the chain case back on correctly and the kick start is siezed again, any ideas?
Neil
kevinneil
Re: Kick start conundrum
Postby modster79 » Sat Jan 11, 2020 8:21 pm
I had the same issue and my problem I found out was two teeth missing off first gear cog and cluster. New cog and cluster all fine.
modster79
Postby Tractorman » Sun Jan 12, 2020 11:21 am
Check to see if the kickstart shaft is fouling the clutch top steel, you should see marking on the clutch.
Postby Delboyli150 » Tue Jan 14, 2020 7:56 pm
Use engineering blue on clutch, then put side case back on with just a few nuts, try kickstart gently, Take side case off, then you will see where it is scoring (touching).
Delboyli150
Postby Knowledge » Tue Jan 14, 2020 11:18 pm
You might be able to address the issue with a thicker (or two) sidecase gaskets, but finding out where it is fouling beneath the casing is still the best way forward
Postby Fast n Furious » Wed Jan 15, 2020 2:01 am
Also check the condition of the kickstart shaft retaining circlip.
Postby ROClarke » Fri Jan 17, 2020 7:51 pm
Has one of the two bronze bushes in the casing that the kick start shaft sits in slid back into the casing .
ROClarke
Users browsing this forum: Baidu [Spider], nastro azzurro and 67 guests
