FITTING BGM DAMPERS TO S2 EIBAR
Postby johnnyjarvis » Sun Oct 05, 2014 1:03 pm
Looking to buy bgms for my S2 eibar.
Looks like a there could/will be an issue with the dampers fouling against the side mudguard support bracket on the fork leg. Will they run pretty close or would I have to modify the mudguard brkt. Cheers, Will.
johnnyjarvis
Re: FITTING BGM DAMPERS TO S2 EIBAR
Postby soullad » Sun Oct 05, 2014 8:39 pm
fit fine mate, they are close but they do fit.
If you are wooried they do a thin set now anyways ;)
soullad
Postby peejay » Tue Oct 07, 2014 9:41 pm
hi Johnny
it is a bit snug under the mudguard, i got a club mate to make me a 10mm nylon spacer for each side.
even with that fitted i wouldn't want to have to remove the BGM damper at the roadside but it certainly helps and no one will notice :)
Users browsing this forum: Baidu [Spider] and 71 guests
