Ts1 piston
Ts1 piston
Postby Marrsy7 » Tue Dec 31, 2019 5:35 pm
Putting a new piston in my ts1 (not a rebore) how many miles are recommended for running new piston in ? Regards
Marrsy7
Re: Ts1 piston
Postby coaster » Tue Dec 31, 2019 8:33 pm
Not many really, I'd take it a bit easy for a hundred miles but not too easy, dont be afraid to rev it but dont labour it. Tighten the head down again after 100 miles and you should be good, a few plug chops would be a good idea too
Re: Ts1 piston
Postby ULC Soulagent » Wed Jan 01, 2020 2:32 am
As Jeremy Clarkeson says :D Sum say around a tank of fuel for bedding in rings ;)
ULC Soulagent
Re: Ts1 piston
Postby MickYork » Wed Jan 01, 2020 10:20 am
Out of interest, if it doesn't require a re-plate/bore, why are you changing the piston and not just the rings ?
Re: Ts1 piston
Postby Marrsy7 » Wed Jan 01, 2020 3:01 pm
The top off the piston has a dint in it as if it’s ready to hole piston
Marrsy7
Re: Ts1 piston
Postby gaz_powell » Wed Jan 01, 2020 3:35 pm
Make sure you solve the root cause to the detonation issue before you charge ahead with a piston replacement.
Re: Ts1 piston
Postby Marrsy7 » Wed Jan 01, 2020 7:54 pm
Hi thanks for reply’s did you think it could b a timing prob ?( it has variotronic fitted )
Marrsy7
Re: Ts1 piston
Postby MickYork » Wed Jan 01, 2020 9:10 pm
jetting or an air leak would be other possibilities. Worth doing a leak-down test when you put it back together......followed by plug chops.
Re: Ts1 piston
Postby Fast n Furious » Thu Jan 02, 2020 1:34 am
Altitude above sea level is not something that most of us need to consider really except for the few that live at 600-1000ft above sea level. Up there has upto 1% less oxygen available for combustion.
An engine perfectly tuned for this altitude will run weaker when thrashed on a run out to the coast, potentially leading to piston melts, seizures, recovery truck, embarrassment and depression :o .
Always best to set them up on the rich side if you live up where the air is rarefied.
Re: Ts1 piston
Postby rossclark » Thu Jan 02, 2020 8:03 pm
Interesting point where I live is about 700ft above sea level and with my RT could never get it off the rich side.
Re: Ts1 piston
Postby Knowledge » Fri Jan 03, 2020 1:38 pm
Not even when the barometric pressure was high?
I doubt if 700ft above sea level makes much difference. You will get more effect with cold weather on a sunny winter's day when the air is denser.
I'd try and prove this, but we don't have too many mountains in Suffolk (but we do have a ski-slope)
Re: Ts1 piston
Postby rossclark » Mon Jan 06, 2020 1:13 am
Maybe, I could never get it off the rich side even with what I thought seems quite lean jetting Av264/X7 and mains as low as 110 on a PHBH 30
Users browsing this forum: Baidu [Spider] and 50 guests
