citydaz wrote:try Mike Phoenix
Toddy wrote:http://www.mikephoenix.co.uk/
There you go and welcome to the forum![]()
Ive used these good plates and service
St George wrote:Tippers all day long. Old family business in Devon. You will have to send a copy of your V5 by email. About £30, they are pressed ally.
57Speedster wrote:Is it permissible to have a Non-Standard size black & silver plate ?
The standard 9" x 7" Motorcycle plate is just a bit too wide for my 64 Cento, and catches the rear edge of the side panels, when removing them.
Ideally, I'd like a 8.5" x 7" pressed Aluminium plate, (which would be a perfect fit in the Number Plate mounting area), but not sure if that would be Road Legal, or if anyone can make them that size.
Storkfoot wrote:57Speedster wrote:Is it permissible to have a Non-Standard size black & silver plate ?
There is a minimum gap between the digits that is permissible. I can’t recall what it is but it’ll be on the internet somewhere. Personally, I’d just ask Tippers. They’ll know whether it is possible given your actual digits (it’s easier to squeeze in a 1 than it is an 8, if you know what I mean). Also, Tippers are happy to make up non standard sizings.
I suspect that as it is only 1/2 inch, you’ll be fine.
