Ts1 replacement piston Ron Moss Matika piston
Postby al pushpak » Fri Nov 22, 2019 8:15 pm
Hi, I want replace the asso piston in my ts1 kit & was wondering if anyone has used one of the above pistons, my kit is totally standard with no tuning .I run it one of Ron Moss ex box exhausts & a 30mm phbh . I was going to purchase a wossner piston as a replacement but they are out of stock everywhere so was considering one of these. thanks for any info ;)
al pushpak
Re: Ts1 replacement piston Ron Moss Matika piston
Postby Norrie Bodge » Fri Nov 22, 2019 9:00 pm
al pushpak wrote:Hi, I want replace the asso piston in my ts1 kit & was wondering if anyone has used one of the above pistons, my kit is totally standard with no tuning .I run it one of Ron Moss ex box exhausts & a 30mm phbh . I was going to purchase a wossner piston as a replacement but they are out of stock everywhere so was considering one of these. thanks for any info ;)
Got one running in a steel liner TS1
As long as your inlet boost port hasn’t been opened up these pistons are fine...
Wouldn’t a new set off rings for the Asso be suffice? Or is this piston damaged?
Norrie Bodge
Postby al pushpak » Fri Nov 22, 2019 9:11 pm
Hi Norrie thanks for the quick reply & info, the cylinder is totally standard with no porting, my asso piston is little scuffed but nothing major, I just fancied upgrading to a lighter piston ;)
al pushpak
Postby dscscotty » Fri Nov 22, 2019 9:20 pm
Be careful of piston to bore clearance- Avanti piston grades do not match nicasil TS1 grades i:e grade A avanti does not match grade A Asso TS1 The clearance will not be sufficient and will cause issue
Postby al pushpak » Fri Nov 22, 2019 9:33 pm
Ok thanks, I think I will probably wait until the wossner pistons come back into stock as I was told by both AFR & Andy Francis that the wossner piston will be a straight swap for my " B " grade cylinder ;) cheers
al pushpak
Postby Scooterdude » Fri Nov 22, 2019 9:44 pm
Why not use one of the MB Meteor reed pistons designed for the RT reed kit? These come graded, a, b, c, and d. I tried one of the Mitaka ts1 pistons on my RT and found it rather heavy compared with the Meteor or Wossner.
Scooterdude
Postby Norrie Bodge » Fri Nov 22, 2019 10:04 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 3988852292
Give Ron a Pm regarding grade/clearances for your TS cylinder
I thinks his username is grandpa on here
Norrie Bodge
Postby dscscotty » Fri Nov 22, 2019 10:12 pm
He doesn't need to I've told him! if you do contact him tell Ron I said hello and sorry i didn't make him that brew at Lydden!
Postby coaster » Sat Nov 23, 2019 9:23 am
dscscotty wrote:He doesn't need to I've told him! if you do contact him tell Ron I said hello and sorry i didn't make him that brew at Lydden!
The Matica pistons that Ron sells are not tyhe same as ther Avanti ones, I have used one in a standard TS1 and it worked fine untill an air leak killed it. I tried to buy another one to use in an Avanti with a rteed valve but Ron intercepted the sale to tell me it would be suitable for my Avanti as they were made for the TS1.
Hope that helps 8-)
Postby gaz_powell » Sat Nov 23, 2019 12:39 pm
RM pistons on ebay today noted as;
A - 69.97
B - 69.98
I'm sure they did a 69.99 - C shown on website
Having used only one, ring peg very close the inlet edge and made by KHC (Mitaka don't actually make pistons)
Only way to select one against a used nicosil barrel is have the barrel accurately measured.
When I last swapped a TS1 piston in a used barrel, it ended up been a C piston in a B barrel. That's was an asso and AF did the measuring etc. Done loads of miles on it.
Personally I don't think you can go wrong with Asso
Postby al pushpak » Sat Nov 23, 2019 7:34 pm
Thanks for all your replies , think I'm going to wait til the wossner piston's come back into stock, nothing against asso piston's or Ron Moss piston's I just fancied using a wossner as they are said to be a lot lighter. cheers ;)
al pushpak
Postby Scooterdude » Sat Nov 23, 2019 7:55 pm
al pushpak wrote:Thanks for all your replies , think I'm going to wait til the wossner piston's come back into stock, nothing against asso piston's or Ron Moss piston's I just fancied using a wossner as they are said to be a lot lighter. cheers ;)
The MB reed piston is very slightly lighter than the Wossner. Last time I checked there were no spare rings available for the 70 mm Wossner, this was over 6 months ago and I’ve heard nothing since dispite being promised a call as soon as they are available.
Scooterdude
Postby al pushpak » Sat Nov 23, 2019 8:26 pm
Just had a look at the MB meteor reed piston's & they do look a nice bit of kit, I also like the fact they are lighter than the wossner piston. My next question is ( & please be gentle as maths isn't my greatest subject lol! ) that I have measured my cylinder with a digital Vernier gauge internally at several different points & the measurements I get seem to between 69.5 & 69.6 does this seem correct? thanks for any info ;) ps as stated in my earlier post my asso piston is a grade B cheers.
al pushpak
Postby Fast n Furious » Sat Nov 23, 2019 9:18 pm
Verniers can't be used accurately enough when measuring cylinder bores. You need a bore micrometer.
Postby al pushpak » Sat Nov 23, 2019 9:23 pm
Thanks, just had a PM regarding the correct way to measure the cylinder will try & get it measured at a motorcycle cycle dealer near my place of work thanks again for all your input
al pushpak
Postby carlos fandango » Sat Nov 23, 2019 11:50 pm
I changed from Asso to Wossner on my TS in the summer , Wosner has a lower crown profile than the Asso , so the head needed reprofileing.
carlos fandango
Postby gaz_powell » Sun Nov 24, 2019 10:21 am
My well used grade B with C piston is back after an emergency loan to a friend to go Poland. Piston looking a bit tired so both off to be measured/checked on Monday. Hoping it will take the next piston before a replate.
I'll report back Monday.
Postby al pushpak » Sun Nov 24, 2019 10:26 am
Anyone ever used one of the Casa reed valve 70 mm pistons in their Ts1 ? cheers
al pushpak
Postby ULC Soulagent » Sun Nov 24, 2019 10:37 am
I’ve a casa reed piston for my spare ts1 that mb had tuned for touring, turns out the ring peg position will only fit in a standard barrel and the crown has a flatter profile so ended up using mb meteor piston and head. Managed to get a standard ts1 barrel which needs a replate so the casa piston n black line head will be used for that as a spare spare :lol:
ULC Soulagent
Postby al pushpak » Sun Nov 24, 2019 11:56 am
I thought the Casa pistons had the same crown heights as the asso's 39mm but then again all this piston malarkey has definitely been a learning curve lol! :D
al pushpak
Users browsing this forum: No registered users and 61 guests
