BGM Pro ignition
BGM Pro ignition
Postby Thackers » Sat Nov 16, 2019 6:50 pm
Hi, im currently rebuilding for a friend a SX150. Ive built the engine from an empty casing and only used top quality parts as my friend instructed. Now ive got the engine back into the scoot and for the life of me i cant get it to start :oops: my ask for help here is in setting the timing. The flywheel has no windows so you cant see the marks on the black box to line up with any corresponding marks on the flywheel. Ive got TDC and the firing point 17 degrees before and set the stator as a guesstimate . I have a timing light at the ready to check the arrow on my marks but without it running i could be a mile out!!
Is there a way to set the ignition without all the guess work? Which seems to me to be a set back on the indian flywheel. Or am i missing something obvious :oops: :oops: :oops:
Thanks.
Dave
Thackers
Re: BGM Pro ignition
Postby Knowledge » Sat Nov 16, 2019 7:39 pm
Can you take the spark plug out (so there is no compression) and turn the engine over using a battery drill or impact driver whilst operating the timing light?
Already I am thinking that you need an extra pair of hands for this.
Postby Tony Hart » Sat Nov 16, 2019 8:19 pm
There are timing marks on the flywheel itself to get you in the parish.
Tony Hart
Postby Thackers » Sun Nov 17, 2019 12:47 am
Tony Hart wrote:There are timing marks on the flywheel itself to get you in the parish.
Yeah, I've used them but no joy, I've almost broke my leg kicking it over today (slight exaggeration on the leg) it's almost there at times then a backfire or two and nothing.
Thackers
Postby coaster » Sun Nov 17, 2019 1:06 am
it should start even if its several degrees out, sound like you need to go back over EVERYTHING, timing marks etc.
Postby MickYork » Sun Nov 17, 2019 8:57 am
Knowledge wrote:Can you take the spark plug out (so there is no compression) and turn the engine over using a battery drill or impact driver whilst operating the timing light?
I used this method myself with good results, just be aware that when spinning the flywheel you may un-fasten the nut (L/H thread).
I never checked the nut after setting the timing and consequently sheared the woodruf key :oops:
Postby ULC Soulagent » Sun Nov 17, 2019 10:45 am
Ya ain’t got one of those dodgy flywheel with the key slot in the wrong position ?
ULC Soulagent
Postby Thackers » Sun Nov 17, 2019 2:02 pm
Guys, thanks for the advice, if I can ask? How do you set the timing with the strobe light if it's not connected to the spark plug? My timing light has a plug and a spark plug connection, nothing else. Don't I need a spark to make the light strobe? Worried now if I've a dodgy flywheel
Thanks again.
Thackers
Postby coaster » Sun Nov 17, 2019 3:21 pm
Thackers wrote:Guys, thanks for the advice, if I can ask? How do you set the timing with the strobe light if it's not connected to the spark plug? My timing light has a plug and a spark plug connection, nothing else. Don't I need a spark to make the light strobe? Worried now if I've a dodgy flywheel
Thanks again.
If your ignition is working it will still generate a spark even without the plug fittrd but you will need tp earth the metal body bof the plug to the engine csds. If it doedny spark then you have found your problem
Postby missing lynx » Sun Nov 17, 2019 3:43 pm
For the strob to work the engine must be running saying that if the stator is fixed with the bolts roughly in the centre of the slot it should run then as long as your timing marks are right the timing should be setable are you sure it's sparking? I am assuming the top ends basically std and you've given the carb a good clean
Postby Thackers » Sun Nov 17, 2019 4:31 pm
Carb is a brand new scootopia replica of the sh20 (I think that's the one) I have a good spark and the cyl is a Italian 150 bored to 175cc which was working fine in another engine. The carb is jetted as it came 50 pilot 50 choke and a 105 main I think. It did have 2 slides but I just Left it as it was. I know the piston is the right way on Arrow down and squish was around 1.3 mm. I'll try the drill method and see if I can establish anything that way. Thanks
Thackers
Postby missing lynx » Sun Nov 17, 2019 5:37 pm
I'm not familiar with the BGM stator but is it possible to fit it in total the wrong position?
Postby bookertmgs1 » Sun Nov 17, 2019 8:47 pm
Scooter should start even if timing is significantly out.
Presuming you have got a spark - have you tried a blast of easy start just to get it to fire and turn over. a bit of encouragement is often enough.
plug wet or dry ?
bookertmgs1
Postby Thackers » Sun Nov 17, 2019 10:56 pm
Thanks to all who gave advice and help on this. It turned out to be a sheared woodruff Key :oops: :oops:
All timed up as suggested with the drill and timing light, started 2nd kick.
Thanks to all again.
Dave.
Thackers
Postby dave999 » Fri Jan 10, 2020 10:55 am
your timing light would normally use an inductive pickup to trigger when a spark is produced. i.e it detects high voltage pulses in the spark plug lead
The lamp is powered from 12 volt battery the switch to flick on the strobe light is a transistor that switches on the lamp only when it sees a pulse from the trigger clamp. that pulse happens when the spark plug fires
put the trigger clamp round the spark plug lead with its arrow facing the plug. timing will be 1-3 degrees out if you put it backwards.
power up the light by connecting it to 12 volt battery
the crocodile clip lead is not used when setting timing. its for general test light work, static setting of points based timing and if the timing light does it dwell setting...you don';t need it here
rest the plug on the engine cowl and every time it sparks your timing light strobe should fire. doesn't matter if the motor is turned over under its own steam or you are winding it over by hand. provided it turns a spark of sorts will be produced.
something to spin the crank the correct way from either end, cush-drive or flywheel is key as the work you need to do checking the timing can't be done while running down the road.
kick back at the kick start MIGHT be an indication of far too advanced. i.e the ignition event tried to make the crank spin backwards. This will break stuff
back fire can be a multitude of things but again can be linked to way too much or way too little advance. i.e you are igniting a charge when the exhaust port is somewhat open at or very soon after ignition..... hard to do as there is little/less compression if it is open which is why it does it only infrequently. to Go off pop you are not necessarily igniting the last induction stroke of properly mixed fuel and air ... it will be quite wet in there it will be a function of what is evaporating more than anything else luck (bad) rather than timing in some cases
dave
Dave
dave999
Users browsing this forum: No registered users and 38 guests
