by HxPaul » Thu Oct 24, 2019 8:49 pm
How long should you leave the scooter engine inflated using a leak down kit.The top end of my engine has been inflated for at least 3 hours and it hasn't gone down yet.
by Norrie Bodge » Thu Oct 24, 2019 9:33 pm
HxPaul wrote:How long should you leave the scooter engine inflated using a leak down kit.The top end of my engine has been inflated for at least 3 hours and it hasn't gone down yet.
I thinks it’s safe to say you’ve done a good build m8
Norrie Bodge
by watty-rugby » Fri Oct 25, 2019 7:31 am
watty-rugby
by coaster » Fri Oct 25, 2019 8:56 am
3 hours is quite amazing, did you use greases in the bore
by HxPaul » Fri Oct 25, 2019 6:03 pm
HxPaul wrote:How long should you leave the scooter engine inflated using a leak down kit............
4 replies and not 1 that answers the question
by Bogie » Fri Oct 25, 2019 7:06 pm
i leave mine under pressure for 5 mins or so , if no massive drop im a happy bunny ... so 3 hrs i would say your defo good to go
Bogie
by nastro azzurro » Fri Oct 25, 2019 7:09 pm
2 minutes is enough for testing.
I test gas installations and dependant on volume 2 minute test is adequate for most average installations ; and they have a much larger volume than a Lambretta motor!
Allow a minute for stabilisation then a test of two minutes.
Try to ensure a reasonably stable temperature when testing as this will influence the test.
nastro azzurro
by nastro azzurro » Fri Oct 25, 2019 7:15 pm
As an aside, if your test at 3 hours hasn’t dropped I’d make sure you are actually testing the motor and not just testing the test equipment!
nastro azzurro
by bookertmgs1 » Fri Oct 25, 2019 10:07 pm
Leave it pressurised - have a cup of tea maybe a tidy up. If it’s not dropped then your are fine.
I also tend to do a check day after too - not sure why - I just do !
bookertmgs1
by HxPaul » Sat Oct 26, 2019 9:30 am
Thanks for the replies.
Users browsing this forum: No registered users and 87 guests
