Lapping flywheel
Lapping flywheel
Postby roli150lam » Sat Oct 19, 2019 10:25 am
Is it neccessary to lap the flywheel to the crank?
If the answer is yes,why are they not marketed as a pre-matched pair?
roli150lam
Re: Lapping flywheel
Postby Rob Miller » Sat Oct 19, 2019 3:17 pm
It's not neccesary to lap the flywheel to the crank. You can use lapping to recover damage to the tapers.
Just make sure the flywheel nut is tightened to the recomended torque of 50lbs/ft. (Ive corrected the torque setting after checking the figure quoted in Sticky's manual)
Rob Miller
Postby Toddy » Sat Oct 19, 2019 8:25 pm
I always lap mine to suit so the flywheel is a good fit on the taper , matched pair :shock: that’s being sensible :lol:
Postby bsso78 » Sat Oct 19, 2019 8:33 pm
Toddy wrote:I always lap mine to suit so the flywheel is a good fit on the taper , matched pair :shock: that’s being sensible :lol:
Do you lap your toupe to your napper in case of string winds?
bsso78
Postby Toddy » Sat Oct 19, 2019 8:51 pm
Yes with gorilla glue off wiggy in your village
Postby Simon_T » Mon Oct 21, 2019 9:08 pm
recommendations for the gorilla glue please mr T :lol: :lol: :lol:
Simon_T
Users browsing this forum: No registered users and 50 guests
