Current consensus on rear hub bearings?
Postby vegansydney » Sat Oct 05, 2019 3:05 pm
What is the current consensus on rear hub bearings? I normally re-use originals, but I've exhausted my stock. What is recommended, and more importantly, what I should I avoid?
BGM, Casa, MB, Tutto/Stratos (RIV stamped), others?
vegansydney
Re: Current consensus on rear hub bearings?
Postby Scooterdude » Sat Oct 05, 2019 4:24 pm
Ive fitted a few Scootopia ones without issue. Have also removed a failed one with plastic ball cage, not sure but I think it was a Casa.
Scooterdude
Postby Knowledge » Sat Oct 05, 2019 9:22 pm
I have used the new double-row bearing from AF.
It is the best bearing I have used for the back hub. No play at all, even without the end plate fitted.
Read my Oily Rag article in the recent Jetset.
Postby rossclark » Sat Oct 05, 2019 9:45 pm
Knowledge wrote:I have used the new double-row bearing from AF.
That's what I'll be replacing the plastic caged MB one with this winter.
Postby vegansydney » Thu Oct 10, 2019 3:22 am
Thanks for recommendations. Do all MB ones have a plastic cage? Or was it just one particular version?
vegansydney
Postby Warkton Tornado No.1 » Thu Oct 10, 2019 11:04 am
vegansydney wrote:Thanks for recommendations. Do all MB ones have a plastic cage? Or was it just one particular version?
I don't know whether MB have changed their product, but the plastic caged rear hub bearings are 'out there' as I have happened across two in other engines, which, of course, were substituted for other bearings (@ my own cost) as I have a conscience.
I doubt that I have missed any statement by MB, but for a manufacturer that thrives on his own publicity, especially given the opportunity to slag off other's products, I am rather surprised that there is not a very public announcement about this product whilst taking full responsibility for allowing them on to the market :!:
Postby al pushpak » Fri Oct 11, 2019 7:23 am
+ 1 ;)
al pushpak
Postby HxPaul » Fri Oct 11, 2019 8:39 am
MB have changed to metal cage,but I dont know when they changed.
Postby Norrie Bodge » Tue Jun 23, 2020 3:00 pm
Hi mate
Did you use the original bearing retaing plate or do you need a newer design from AF
cheers
Norrie Bodge
Postby dscscotty » Tue Jun 23, 2020 5:18 pm
Scootopia for me, good copies of the original RIV type, also used JBL Indian ones which have also been fine
Postby Warkton Tornado No.1 » Tue Jun 23, 2020 7:13 pm
dscscotty wrote:Scootopia for me, good copies of the original RIV type, also used JBL Indian ones which have also been fine
That's interesting about the Scootopia bearings. :idea: Other than avoiding the MB plastic caged efforts like the plague, there are one or two canny dealers that sell good used OEM Innocenti/Serveta ones, from time to time.
As is often the case, AFR is undoubtedly supplying a well engineered solution, but for the fact of the misalignment of rear to front. That may be of no significance, but I'd prefer to keep the wheels in line if possible.
I doubt that it concerns some of us, but as the AFR rear hub bearings are not the only 'solution' then they would not be my choice.
These deviations can all stack up & conspire to cause issues. We already accept compromise with certain tubeless rims & although the SIP are a good product (& centralise radially on the hubs rather rely on the shear strength of the M8 fasteners) they have an offset too, so should be used as a pair, front to back, IMHO.
Postby Knowledge » Tue Jun 23, 2020 10:10 pm
So how do you check that your wheels are in-line?
Postby Warkton Tornado No.1 » Wed Jun 24, 2020 2:13 am
Knowledge wrote:So how do you check that your wheels are in-line?
My procedure is for when just spare rims are fitted, though deflated tyres might allow the process :?:
On some kind of stand, set the rear vertical, by packing one side. A really good spirit level is required. But I bet a Buzzwangle would do..... :)
Arrange the clamping of a pair of straight, metal sections to the rear rims. They should bring in to alignment the front wheel, which is fairly obvious.
Now, with your Buzzwangle, Ooops! I mean spirit level, check for vertical.
Go figure the results :idea:
Users browsing this forum: Baidu [Spider] and 72 guests
