Standard with Steroids
Postby Bilko » Thu Oct 03, 2019 4:46 pm
If you had a standard 200 barrel. What could you do to it to give it a bit of torque for a trailer/luggage and touring?
Does this set up exist? I know there has to be a compromise somewhere, but I've yet to find the right one.
It gets costly going through England and France.
I don't want to fork out for another kit. I have TS1230, RT230 and GT193 engines. The TS1 gave me the best fuel economy at approximately 40-ish MPG.
So, I want to see what a standard barrel could do with steroids.
Bilko
Re: Standard with Steroids
Postby Scooterdude » Thu Oct 03, 2019 5:00 pm
I know Harry Barlow was offering a touring tune using an indian 200 barrel bored out to 70mm, 60 or 61 stroke crank think MB offers similar.
Scooterdude
Postby Solid Air » Thu Oct 03, 2019 6:22 pm
I loved my old MB Honda 205 conversion with a 26mm carb which I think would be along the lines of what you're asking for Bilko. Perfect timing too as MBD have been pushing their new Honda-type pistons over the last few days ;)
Postby Adam_Winstone » Thu Oct 03, 2019 7:14 pm
Straight 70mm reborn 4.8 4th, clubman, clubman.
Job done.
Postby MickYork » Thu Oct 03, 2019 8:38 pm
Would a longer conrod (116) and a base packer give a bit more torque ?
Postby duncan1958 » Thu Oct 03, 2019 9:31 pm
Anyone used the ally cylinder steel liner bored out to 225 kit that comes with head and studs gaskets etc ?
Bit of a high jack of thread but on topic ;)
( 183489442176 ) ebay number
duncan1958
Postby rossclark » Thu Oct 03, 2019 10:00 pm
MB has just released a new Honda 205 a-like piston...
Postby ULC Soulagent » Fri Oct 04, 2019 1:43 am
duncan1958 wrote:Anyone used the ally cylinder steel liner bored out to 225 kit that comes with head and studs gaskets etc ?
They are shite, avoid at all costs unless you like having seizures for fun ;)
ULC Soulagent
Postby duncan1958 » Fri Oct 04, 2019 11:44 am
Will give it a body swerve on your recommendation.
Thanks for the advice
duncan1958
Postby Knowledge » Fri Oct 04, 2019 1:25 pm
Superhooper on here has a standard 200 Indian barrel with a couple of minor port tweaks and a bolt-on LTH reed valve. It also has a boost port opposite the exhaust.
It runs on a BGM box pipe and 26mm Dell'orto and runs really well. All day, every day.
I used it for the Italian job in 2017, and it was only when I got it home that I discovered it wasn't a 225 Rapido.
It strikes me as great value of money.
Postby Bofs » Fri Oct 04, 2019 2:46 pm
Darrell Taylor did a Scootering guide on GP200 Bang for Bucks tuning, might be worth getting a hold of that, very enlightening.
Actually it`s all on the website for free :D
Bofs
Postby dickie » Fri Oct 04, 2019 5:40 pm
Bofs wrote:Darrell Taylor did a Scootering guide on GP200 Bang for Bucks tuning, might be worth getting a hold of that, very enlightening.
Yes, I used that guide along with mb advice on port timings to tune a small block for very little money.
Went really well. .....for 40 miles when I melted a piston :lol:
On a new piston now and I'm running in a bit more sympathetically.
Apart from rebore to 175 and head machine work, I could have done the whole thing for about 20 quid.
Postby Bilko » Fri Oct 04, 2019 10:32 pm
Thanks for the replies.
Easiest option Adam Winstone.
Trickiest Dickie.
I'm definitely not up to DIY porting. So I either go standard with a bigger carb and my Avanti Ex Box or get someone to do the Voodoo work on the ports.
Bilko
Postby Mark ULC » Sat Oct 05, 2019 8:03 am
Robert I have a MB modified Indian barrel that I considered getting a tickle for good touring. It would need a new piston as the old Racetour one was done.I asked both Harry B and MB about it. Both said the cost would equal a new kit. So I bought the RT 225. If you can port yourself then it maybe a cheaper option.
Mark ULC
Postby NorthernJordan » Sat Oct 05, 2019 9:33 am
I used stage 4 barrels for a long time but the mahle pistons kept snagging rings. But at 100 quid you could do 4 for the price of a kit. However. After the second time of the rings letting go I bored out to 225 and used one of the avanti pistons. Always used with a NK rally road and a 30mm. This made a great all round set up for rallying, even two up.
NorthernJordan
Postby dickie » Sat Oct 05, 2019 9:42 am
Mick abbey is very good and very reasonable if you don't fancy porting yourself
Postby Bilko » Sat Oct 05, 2019 10:08 am
NorthernJordan wrote:I used stage 4 barrels for a long time but the mahle pistons kept snagging rings. But at 100 quid you could do 4 for the price of a kit. However. After the second time of the rings letting go I bored out to 225 and used one of the avanti pistons. Always used with a NK rally road and a 30mm. This made a great all round set up for rallying, even two up.
What return are you getting fuel wise?
Bilko
Postby steveg » Sat Oct 05, 2019 10:25 am
Malc Andreson (mechanic at MSC) used to get fantastic results with the Honda 205 conversion, but scarcity of pistons means it's not viable these days
steveg
Postby NorthernJordan » Sat Oct 05, 2019 10:52 am
I'll be honest I can't really remember. It liked a big main jet compared to my RT as I guess the cast iron runs hotter. I wanna say about 40 to 45mpg two up. It gave good performance for a nice simple set up, with lots of people asking if it was a TS1 :D
MB have recently redone the honda205 piston but by the time you buy that have the tuning work done you're not thst far off the cost of an RT kit.
A 200 barrel with a quality piston paired with a decent exhaust and carb for what you want can give decent performance. It just won't be earth shattering or give much bragging rights in the pub.
NorthernJordan
Postby Bilko » Sat Oct 05, 2019 11:18 am
To be honest, priority is fuel consumption and as long as it can pull the trailer.
Bilko
Users browsing this forum: Baidu [Spider] and 28 guests
