Which kit have I got.
Postby St George » Thu Sep 26, 2019 4:17 pm
Bought this engine from a novice that had a change of heart building his dream scooter. He was told it was a 185. I have been looking for trade marks, nothing found. It is an all alloy kit with just four head bolts. The inlet manifold is stamped CDC which I don't recognise. The studs on the barrels for the inlet manifold are closer together than a 150 and the port is polished. The piston and bore looked spotless so it's only a recent rebuild, but not built by the novice I bought it from. Started first time with the aid of carb cleaner and ran really nice fortunately. any ideas ? Thanks.
St George
Re: Which kit have I got.
Postby ToBoldlyGo » Thu Sep 26, 2019 5:34 pm
Post a picture.
ToBoldlyGo
Postby St George » Thu Sep 26, 2019 5:39 pm
I cannot post pic's on the dated forum system. I can on up to date systems.
St George
Postby MickYork » Thu Sep 26, 2019 6:54 pm
the studs not fitting a 150 manifold are confusing ? is the CDC (quite common) manifold slotted to fit ?
............or is it a 200 manifold slotted to fit a 150 barrel ?
Postby Knowledge » Thu Sep 26, 2019 8:29 pm
CDC = Malossi (I think)
Is the barrel cast iron or Ali?
Postby Warkton Tornado No.1 » Thu Sep 26, 2019 11:22 pm
A lot of Dell'Orto (solid mount) manifolds were made by CDC (the original UK Dell’Orto importing business, Contact Developments) & many of them became modified to suit Amal, Dell'Orto etc that utilise the rubber sleeve mount. Of all the aftermarket (piston ported) inlet manifolds made for Lambretta (large frames) I consider them the best quality & nicest looking :)
Postby holty » Fri Sep 27, 2019 8:24 am
sounds like an indian aluminium kit, if the inlet studs are closer than a 150 spacing I suspect they have been drilled in the wrong place, ive seen cylinders for sale on ebay with the studs fitted incorrectly it could be one of those, as said earlier a pic would help to be sure.
holty
Postby St George » Fri Sep 27, 2019 12:28 pm
The kit is all alloy including the barrel. The manifold is slotted inwards to reach the studs. As for pictures ! this forum system is very dated and will not accept full size pictures. I can post pictures on the Triumph Owners Forum and Facebook as it is up to date with technology, maybe they have more funds. I have tried reducing pictures in size, still won't accept them. Thanks for replies so far.
St George
Postby Solid Air » Fri Sep 27, 2019 12:55 pm
Give postimages.org a try for pictures as a forum hotlink
Postby Knowledge » Fri Sep 27, 2019 1:01 pm
Sometimes if you email a photo to yourself, the apps will ask you if you want to reduce the size of the file. If you opt yes, you will get a reduced size photo for very little effort.
My phone offer me this choice when I forward photos to my own email account.
Postby St George » Fri Sep 27, 2019 3:25 pm
Thanks lads will experiment.
St George
Postby coaster » Fri Sep 27, 2019 3:33 pm
you need to use a photo hosting service like Flicker or Photobucket.
Postby missing lynx » Fri Sep 27, 2019 6:37 pm
Has it got a std port layout or has it got extra ports?
Postby St George » Sat Sep 28, 2019 11:31 am
Hi Lynx. Cannot tell as the engine is intact as it's a recent rebuild. Not going to pull it to bits just for a look, thanks anyway.
St George
Postby missing lynx » Sat Sep 28, 2019 8:26 pm
If it's intact how do you know it's all alloy and not steel lined?
Postby ToBoldlyGo » Sat Sep 28, 2019 10:14 pm
Good point. Well made.
ToBoldlyGo
Postby St George » Sun Sep 29, 2019 2:55 pm
The barrel is alloy, it may well have a liner fitted. May even pop the head off in the week as I have found a spare head gasket in the cave.
St George
Postby davla » Sun Sep 29, 2019 10:28 pm
Why don't you just ask the person you bought it from?
davla
Postby St George » Mon Sep 30, 2019 5:36 pm
Cause he didn't build it. :o
St George
Postby MickYork » Mon Sep 30, 2019 5:54 pm
Probably worth taking the barrel off and seeing what it is. Check the squish and head profile while you've got it apart.
Users browsing this forum: No registered users and 39 guests
