by gizmo » Thu Sep 19, 2019 4:51 pm
I was going to get the sip Speedo but when you add all the extra bits on they don't come out much different to a gamma unit from scootronics. Not bothered about standard looks so which would you go for.
gizmo
by Solid Air » Thu Sep 19, 2019 5:17 pm
I like the SIP for the standard fitment but CHT and clock text very small for old eyes.
The Gamma Tech has bigger text and extra functions, ie EGT. I found it needs a more powerful magnet for the speedo and positioned as close as poss for the reading to be steady.
Hope this helps
by Solid Air » Thu Sep 19, 2019 5:23 pm
Should have said, I'd go for the Gamma because of the EGT as it's been invaluable for my set-up.
by gizmo » Thu Sep 19, 2019 8:07 pm
Solid Air wrote:Should have said, I'd go for the Gamma because of the EGT as it's been invaluable for my set-up.
thanks for that. I have found your adventure with the Quattrini very entertaining
gizmo
by Solid Air » Thu Sep 19, 2019 8:40 pm
gizmo wrote:Solid Air wrote:Should have said, I'd go for the Gamma because of the EGT as it's been invaluable for my set-up.
Cheers Gizmo, entertaining certainly is the word!
by Toddy » Fri Sep 20, 2019 6:50 am
+1 on the Gamma excellent bit of kit
by col68 » Fri Sep 20, 2019 7:52 pm
Got an acewell in my s2 round one with egt.
col68
by Scooterdude » Sat Sep 21, 2019 8:32 pm
I’ve got a Gamma and love it. As above nice big text and well lit, it’s saved the day a few times but my only grumble is the k type EGT sensor, if you get 3k out of one you’ve done well, ive tried the £25 ones as well as the £4 eBay ones none of them seem to last unfortunately.
Scooterdude
by Solid Air » Sat Sep 21, 2019 9:17 pm
Have you got the exposed wire type or the solid tip?
by Scooterdude » Sat Sep 21, 2019 10:16 pm
Solid Air wrote:Have you got the exposed wire type or the solid tip?
not sure what you mean??
Scooterdude
by Solid Air » Sat Sep 21, 2019 10:29 pm
This type?
Or this type?
I've heard the first type gum up, I use the second type and it would make sense that they last longer (?).
by Scooterdude » Sun Sep 22, 2019 7:35 am
Ah, never seen the first type before but the second “enclosed “ type is what I’ve always used. When they go they usually jump to 1000 degrees for a few minutes and the display starts flashing then drop to 0 and that’s it it’s dead.
Scooterdude
Users browsing this forum: No registered users and 170 guests
