What is the current thinking on cylinder kits?
Postby Donnie » Tue Sep 10, 2019 2:19 pm
Right so I have an engine casing that needs ally welding to the crankcase mouth, its currently small block spacing but if Im going to use it then Ill happily have the work done to have it done to 200 spacing.
So, I do NOT want anything revvy and racy, I want some speed but touring & reliability are my most important factors and on that basis im ruling out cast iron kits, TS1s and Quattrinis.
As an add on, I don't want a long stroke crank and I don't care if its an expansion pipe or not as long is doesnt hang too low and carb wise would rather stick to PHBH 30. Already have an LI150 gearbox and happy to stick with 4/5 plate clutch.
So, as Im quite out of the loop these days Im after some discussion about what the general consensus is on a good quick (not racy) touring kit.
Donnie
Re: What is the current thinking on cylinder kits?
Postby MickYork » Tue Sep 10, 2019 4:36 pm
Avanti TT3 225.......now a proven kit with plenty of info'.
Postby Scooterdude » Tue Sep 10, 2019 5:27 pm
Touring, reliable, economical,PHBH30, not cast iron. RT 225 with reed conversion ticks all the boxes.
Scooterdude
Postby Donnie » Tue Sep 10, 2019 8:25 pm
Hmmm cheers guys, must admit, the avanti looks the favourite with a matched pipe
Donnie
Postby Scooterdude » Tue Sep 10, 2019 8:33 pm
Donnie wrote:Hmmm cheers guys, must admit, the avanti looks the favourite with a matched pipe
isn’t the Avanti cast iron but with a Nicasil liner?
Scooterdude
Postby MickYork » Tue Sep 10, 2019 8:39 pm
No, ally with Nicasil lining.
Don't think you can put Nicasil on iron ?
Postby Donnie » Tue Sep 10, 2019 10:29 pm
Avanti is definitely all ally and nicasil.
Donnie
Postby Scooterdude » Tue Sep 10, 2019 11:07 pm
MickYork wrote:No, ally with Nicasil lining.
i think you are right. I could have sworn blind i read it was plated cast iron my mistake.
Scooterdude
Postby HxPaul » Wed Sep 11, 2019 8:47 am
I have two Casa 185's with PHBL 25 carbs and clubman exhaust's.Not very fast(60 mph all day)but ultra reliable.
Postby landybretta » Wed Sep 11, 2019 9:48 am
HxPaul wrote:I have two Casa 185's with PHBL 25 carbs and clubman exhaust's.Not very fast(60 mph all day)but ultra reliable.
+1
landybretta
Postby ULC Soulagent » Wed Sep 11, 2019 5:29 pm
RT225 reedvalved touring all day long :D
ULC Soulagent
Postby corrado » Wed Sep 11, 2019 11:51 pm
The BGM RT kit has a very similar port layout to the Mugello. I fitted an LTH reed valve conversion to my Mugello 225 and it totally transformed it but you're adding £200 + to your total and an out of the box BGM195 or 225 kit ticks nearly all the boxes for what most riders want.
corrado
Postby Donnie » Sat Sep 14, 2019 11:40 am
so on the BGM225 with a reedvalve what exhaust ye using?
Donnie
Postby dickie » Sat Sep 14, 2019 1:51 pm
corrado wrote:The BGM RT kit has a very similar port layout to the Mugello. I fitted an LTH reed valve conversion to my Mugello 225 and it totally transformed it but you're adding £200 + to your total and an out of the box BGM195 or 225 kit ticks nearly all the boxes for what most riders want.
Seems odd to spend all that extra money on a Reed valve when there are so many Reed valve kits available. Rb22, monza, ss225, gt200 etc.
Is there something special about rt225 with reed?
Postby ULC Soulagent » Sat Sep 14, 2019 3:53 pm
Yes :D it’s works very well, pulls like a Massey Ferguson from 2500 upwards while returning great fuel mpg.
Everybody has their own opinions on kits depending on weather you want too race or tour.
I run 25 delly on touring setup and if I wanna race then on goes the 30 delly ;) simples
ULC Soulagent
Postby brumtony » Sun Sep 15, 2019 8:45 am
Have you tried a quattrini ??? , they pull from nothing and you can go on a normal ride out hardly changing gear because of the torque or you can ride it like you stole it 6-8000 rev band .This kit is so versatile its untrue 40 mph for big steep hills just twist the throttle and its pulls you up when you see all around dropping down a cog .
brumtony
Postby Scooterdude » Sun Sep 15, 2019 9:22 am
Donnie wrote:so on the BGM225 with a reedvalve what exhaust ye using?
For touring with plenty of low down grunt I’m using a CST3 on mine, was running an NK road but prefer the Chiselspeed pipe.
Scooterdude
Postby ULC Soulagent » Sun Sep 15, 2019 1:19 pm
Donnie,
I’m using Bgm v3 on mine and happy with it. A fellow club member has the same kit but used the Bgm V4 and it ended up strangling the engine :shock: weird so he reverted back too a dev-tour which transformed it.
ULC Soulagent
Postby Donnie » Sun Sep 15, 2019 3:13 pm
Ah, got that on the 186 muggy currently :-)
Donnie
Postby Donnie » Sun Sep 15, 2019 3:14 pm
Donnie,
aye, I had 2 bgms and both broke in little time :-/ Don't think I'd bother again
Donnie
