Sip Speedo question
Sip Speedo question
Postby gizmo » Sat Aug 03, 2019 9:25 am
Going to fit sip Speedo in new build. Apart from actual Speedo what else do I need. Seems to be lots of different leads and add ons. Thanks
gizmo
Re: Sip Speedo question
Postby ULC Soulagent » Sat Aug 03, 2019 9:40 am
All the connectors are explained in the fitting manual with the CHT lead only heading down to the cylinder head.
Optional extras you can buy are 3 types of speedo speed sensor’s ( Magnet Setup,Electronic box & now GPS)
Also u can now get an EGT setup which stops using the CHT part
CHT- Cylinder Head Temperature
EGT - Exhaust Gas Temperature
ULC Soulagent
Postby gizmo » Sat Aug 03, 2019 11:22 am
ULC Soulagent wrote:All the connectors are explained in the fitting manual with the CHT lead only heading down to the cylinder head.
Any preference on which to use. I am starting from scratch. Non battery
gizmo
Postby ULC Soulagent » Sat Aug 03, 2019 12:17 pm
I have the latest v2 Running dc which helps stop the low rev flickering, it also has backlight brightness control which is a lot better than the non adjustable V1. I run the electronic box for my speedo as it gives better clearance inside the headset and also takes away the need for undoing the speedo outer knurled nut all the time. I run the EGT instead of the CHT which is now a Trailtec version.
I’d get one of Antony Tambs intelligence converter that will give u a stable electric pulse and stop the flickering rev counter.If ur using a standard speedo cable then make sure ur using the proper inner( can’t remember of the top of my head which one is preferred) If ur running a standard engine then I wouldn’t bother with the CHT but if ur running and high spec engine then it would be beneficial too fit it or go one step further and fit the EGT.
Hope this helps
Regards
Shane
ULC Soulagent
Postby gizmo » Sat Aug 03, 2019 2:36 pm
ULC Soulagent wrote:I have the latest v2 Running dc which helps stop the low rev flickering, it also has backlight brightness control which is a lot better than the non adjustable V1. I run the electronic box for my speedo as it gives better clearance inside the headset and also takes away the need for undoing the speedo outer knurled nut all the time. I run the EGT instead of the CHT which is now a Trailtec version.
Hope this helps
Regards
Shane
Lot of help Shane, thanks very much
gizmo
Postby Watfordwhite » Sun Aug 04, 2019 3:57 pm
Mr Tams now recommends if your using the SIP fuel sensor do not use his DC supply.
The SIP used ground as a reference point for the fuel sensor. As I found out the hard way..
Watfordwhite
Postby Fast n Furious » Tue Aug 06, 2019 12:17 am
Unless you are young or still lucky enough to retain 20/20 vision, then you probably isn't going to be able to read the pathetically small temp display anyway. So it won't matter if its CHT or EGT :roll:
Postby ULC Soulagent » Tue Aug 06, 2019 5:44 am
Fast n Furious wrote:Unless you are young or still lucky enough to retain 20/20 vision, then you probably isn't going to be able to read the pathetically small temp display anyway. So it won't matter if its CHT or EGT :roll:
:lol: agree with you on that one FnF
ULC Soulagent
Postby coaster » Tue Aug 06, 2019 8:11 pm
I was going to make the same point, its a shame that SIP didnt put a bit more thought into it. It would be much more usable of you could fully configure the displays, I'd have the dial reading speed rather than revs and the you the large digital display reading temp. The fuel warning is nigh on useless too as it just flashes the odometer display to alternate with the word FUEL. Literally, blink and you will miss it.
Postby Watfordwhite » Tue Aug 06, 2019 8:26 pm
I’ve got a Vespa 90 SIP fitted to the leg shield tool box on my S2.
Using a EGT, fuel and rev counter only. The reading is a good size
Watfordwhite
Postby coaster » Tue Aug 06, 2019 8:43 pm
Watfordwhite wrote:I’ve got a Vespa 90 SIP fitted to the leg shield tool box on my S2.
I think the Vespa ones use the same display, maybe you have reasonably good eyesight? I need glasses for reading so really struggle with small digital displays :(
Postby gizmo » Wed Aug 07, 2019 10:08 am
So probably better fitting a separate unit for temperature. I could fit one in legshield tool box. Trail tech or similar ?. Will be running rb 20 so would be beneficial
gizmo
