Crankshaft please recommend 58/107
Postby readsandypaul » Sun Aug 04, 2019 3:58 pm
Can someone recommend a good crankshaft i have fitted a tameni and it has gone badly wrong i think i will strip down tommorow to make sure, this is the second one i have herd of go badly wrong in 2 weeks both only fitted for 1700 miles and a lot less the second one. Can anyone recomend a good one. To be fitted to a gp200 engine with a mugello 225 top end, all was new. i dont fancy another tameni after these problems. Help please, thanks Paul.
readsandypaul
Re: Crankshaft please recommend 58/107
Postby ULC Soulagent » Mon Aug 05, 2019 12:40 am
When u say horrible wrong ?
What let go ?
Who put crank in?
Tameni cranks are pretty very solid as an entry level performance crank.
Next step up would be SIP
ULC Soulagent
Postby dscscotty » Mon Aug 05, 2019 12:35 pm
+1-I build my own cranks and Tameni crank webs are very good, usually tight on the pin etc, the big ends and rods are fine to, what do you think has gone wrong? Big end?
Users browsing this forum: No registered users and 56 guests
