GP front hub.
GP front hub.
Postby bluebob » Sat Aug 03, 2019 9:55 pm
when positioning my front hub between the fork links I have a gap of roughly 8mm .its an indian gp.just want to know is it common to use shims .I am thinking of shimming under the inner hub nuts.any thoughts please?
bluebob
Re: GP front hub.
Postby missing lynx » Sat Aug 03, 2019 11:48 pm
I would think with that bigger gap there's a problem with the links or the forks
Re: GP front hub.
Postby bluebob » Sun Aug 04, 2019 10:56 am
thanks for reply.i have some new links so will try them.if its still the same then its getting some wider nuts to take up the gap!
bluebob
Re: GP front hub.
Postby Knowledge » Sun Aug 04, 2019 10:28 pm
If you found some wider nuts, how would you know if your wheel is correctly centralised?
Just something else for you to think about....
