by Bilko » Tue Jul 30, 2019 8:50 pm
Found the thread for one of my stator bolts knackered. Is there enough room for a Helicoil?
Bilko
by dickie » Tue Jul 30, 2019 9:13 pm
As luck would have it, I'm doing a rebuild for a mate and one of his is gone. The mag housing is off, so it's easy to check before I go bumbling in. I'll let you know tomorrow if you can wait that long.
by Bilko » Tue Jul 30, 2019 9:13 pm
Perfect Dickie! Thank you.
Bilko
by dscscotty » Tue Jul 30, 2019 10:46 pm
yes they can be heli-coiled, done loads
by al pushpak » Wed Jul 31, 2019 7:27 am
I had one go on mine, never done one before, just bought a kit & had a go ! still in now , easy enough to do just take your time. good luck
al pushpak
by coaster » Wed Jul 31, 2019 8:02 am
Sama as above, easy job using one of the cheap ebay kits, had to do one when I built my GT240 a couple of years ago and thats been to Adria and Soria since.
by a.lo » Wed Jul 31, 2019 5:33 pm
yes just done one on a mates engine. should have checked before fitting the mag/ stator and was the last bolt to be tightened.typical
a.lo
by dickie » Wed Jul 31, 2019 8:11 pm
Bilko wrote:Perfect Dickie! Thank you.
Seems a bit pointless now, but, yes, it's easy.
by Bilko » Wed Jul 31, 2019 8:54 pm
dickie wrote:Bilko wrote:Perfect Dickie! Thank you.
Absolutely not. All replies much appreciated.
Bilko
by Angry Bloke » Wed Jul 31, 2019 9:21 pm
How long is the bolt you were using ?
Measure the depth of the hole ,there could be some thread left in the bottom and you may get away with just using a longer bolt and some loctite
Angry Bloke
by Bilko » Thu Aug 01, 2019 8:57 am
I'll check that Peachy, cheers.
Bilko
by Scooterdude » Thu Aug 01, 2019 2:01 pm
Angry Bloke wrote:How long is the bolt you were using ?
or you could use a longer stud and locktite that it, three studs maybe.
Scooterdude
by coaster » Fri Aug 02, 2019 10:24 am
Scooterdude wrote:Angry Bloke wrote:How long is the bolt you were using ?
Probably run into problems with the nuts fouling the flywheel as they would be higher by the thickness of the stator
by Scooterdude » Fri Aug 02, 2019 4:53 pm
coaster wrote:Scooterdude wrote:Angry Bloke wrote:How long is the bolt you were using ?
Obviously you would have to make sure the studs are the correct length, this may involve trimming with a grinder and you may need to use shallow nuts, I’ve got some very shallow m6 nylocks here that would ideal.
Scooterdude
by Bilko » Thu Oct 17, 2019 11:49 pm
Peachy wins a virtual pint.
Finally getting round to put the engine together and with a bit of measuring and a longer bolt, there was ample thread for the bolt to hold properly.
Bilko
Users browsing this forum: Baidu [Spider], Google [Bot] and 133 guests
