Pompeydave wrote:Ok, I spoke to Mark at AF Rayspeed and he was telling me that an expansion chamber on a 185 Casa kit is probably not necessary and is effectively overkill. Even a 48mm Clubman is over the top. He recommended a 42mm Clubman with a 25mm Dellorto or the 26mm Jetex that they supply with their stage4 175 kits.
Pompeydave wrote:Peejay, was yours a Mk1 or the new Mk2?
Pompeydave wrote:Ah right. I've heard several people saying the Mk1's were louder than a loud thing. Apparently the Mk2 is supposed to be quieter, but hey ho, I wanted a louder pipe anyway
Pompeydave wrote:Did a bit more research into this last night and I found a 2011 copy of Scootering that had a 15 pipe Lammie test. Admittedly, it was based on a TS1 cylindered engine breathed upon by Taffspeed to 'road' tune spec, and fitted with Varitronic ignition and a 30mm PHBH Dellorto, but the comparison is still valid between the pipes.
What it showed was that the ADS-3 was the 'Torque king', developing most of it way down the rev range from about 4500 upwards, but tailing off rapidly above 7000. However, the AF Rayspeed NK 'Road' pipe has a wider spread of power, but the torque doesn't start coming in until about 5000, hence it's not quite as relaxed and grunty low down. However, it holds onto the power for longer than the ADS-3, with a gentle drop off all the way through to 8500.
The final figures for the above engine were:
ADS-3: PEAK POWER: 22.3HP (11th out of 15 in a range of 24.8 to 19.4hp) PEAK TORQUE: 21ft lbs @5474rpm (1st out of 15 in a range of 21ft lbs to 15ft lbs), PRICE: £250 +P&P
AF Rayspeed NK Road: PEAK POWER: 24.7hp (2nd out of 15 in the same range as above) PEAK TORQUE: 20ft lbs @6284rpm (2nd out 15 in the same range as above), PRICE: £217 +P&P
This has left me with a dilemma- do I go for the out and out torque king, the ADS-3, or the pipe that won the group test overall but has slightly less torque lower down, the NK Road?
Users browsing this forum: No registered users and 51 guests
