casa ignition spare keys
Postby spud » Wed May 17, 2017 9:05 pm
Does anyone know where i can get some spare keys for a casa ignition?
Neither the key nor the ignition have a number on them
spud
Re: casa ignition spare keys
Postby ToBoldlyGo » Thu May 18, 2017 10:21 pm
Just to complicate things there are at least two keys, to my knowledge. Fortunately I use the same ignition in two other scooters and one of the keys worked in an ignition switch I had picked up. I simply had a couple more cut. It might possibly be the only way you can do it, by finding a key that works and making another. Have any of your mates got the Casa switch fitted?
ToBoldlyGo
Postby JETEX » Sun May 21, 2017 11:30 am
Try Mark at Fast Keys in Essex. He also has a company called Next Day Keys ( 01268-777788 ). He is very good, and did 2 keys for my Casa ignition switch for only £4 each. I'll PM you his personal mobile number.
JETEX
Postby Raveydavey » Sun May 21, 2017 7:02 pm
Had to get spares cut for a casa ignition. Did it via timpsons but Most key cutters can get the blanks but have to send away. They'll take a photocopy. Recon a couple of weeks.
Raveydavey
Postby Storkfoot » Sun May 21, 2017 10:35 pm
I am trying to get spares of the repro Osam keys. This is proving nigh on impossible, sadly.
Postby JETEX » Mon May 22, 2017 10:10 am
Storkfoot wrote:I am trying to get spares of the repro Osam keys. This is proving nigh on impossible, sadly.
PM sent
JETEX
Postby HxPaul » Mon May 22, 2017 10:44 am
Have you tried scootopia,they make the osam barrels and keys.http://www.scootopia.co.uk/product/7342 ... ion-switch
Postby Storkfoot » Mon May 22, 2017 12:33 pm
Scootopia looked to see if they had a spare of my number. They didn't. I have tried two keycutters so far with no luck. I have another couple of leads to follow up but I could do with sorting this before I set off for Adria at the weekend.
Postby sumpmonster » Sat Jul 13, 2019 10:54 am
Fitted a new casa ignition, key snapped after a few uses, searched everywhere for info for new key, Jem came up but with only one key didn't want to send away, so local shop found a blank that fitted and cut new ones, job done. Blank keys are 'SILCA' SM1
Hope this helps anyone looking for a spare. :D
sumpmonster
Postby HxPaul » Sat Jul 13, 2019 4:57 pm
Postby nsaints » Sun Jan 02, 2022 7:48 pm
Got the same issue it seems.
I have a single ignition key for two scooters :?
Contacted Jem who tells me the key number isn’t Innocenti and to try Scootopia
Scootopia have told me they have no spares :(
I need to find a source of blanks and take my single key to a locksmith along with the blanks
I’m reading Silca SM1 as a blank for a CASA ignition
Would anyone be able to confirm if this will also work for a Scootopia ignition?
Sadly both eBay links above have long expired
nsaints
Postby nsaints » Mon Jan 10, 2022 11:15 pm
Went to the local key cutting place and they had a blank off the shelf and cut a new key using my one original key
Wasn’t a Silca blank either
For once something I thought was going to be agro was a non-issue
nsaints
Users browsing this forum: Baidu [Spider] and 81 guests
