Dazts1 wrote:Depending on the pipe you use. Well as long as you use a stub rather than a u pipe. Tap them out to 8mm and use Allen bolts. Far easier to tighten and you can if you like easily drill and lock wire. I’ve used this method for years with no issues.
Sticky wrote:I just had to do a mate's to M8 Timesert for his TS1 but cos it has a Gori pipe with a fixed downpipe we couldn't use Allen bolts. The solution is to take an M7 nut, drill to 6.5mm and cut an M8 thread in it with a tap. That way you have an M8 nut with an 11mm spanner size head.
Bobs2 wrote:Sticky wrote:I just had to do a mate's to M8 Timesert for his TS1 but cos it has a Gori pipe with a fixed downpipe we couldn't use Allen bolts. The solution is to take an M7 nut, drill to 6.5mm and cut an M8 thread in it with a tap. That way you have an M8 nut with an 11mm spanner size head.
Cheers Sticky, at the moment I've got the option to to use am M7 time sert, or drill out to m8. I could also possibly use Allen bolts, I'm looking to see if I can turn down the heads to 11mm diameter. As I've still got some options open to me which would you go with?
dickie wrote:Why not helicoil?
Sticky wrote:Bobs2 wrote:Sticky wrote:I just had to do a mate's to M8 Timesert for his TS1 but cos it has a Gori pipe with a fixed downpipe we couldn't use Allen bolts. The solution is to take an M7 nut, drill to 6.5mm and cut an M8 thread in it with a tap. That way you have an M8 nut with an 11mm spanner size head.
If you tap out to M8 it's still an aluminium thread. I think I'd rather have an M7 Timesert if there's still enough aluminium, then any exhaust will fit and you'll have a choice of whichever way you want to fasten it. Others may disagree.
Bobs2 wrote:dickie wrote:Why not helicoil?
Thanks for the response dickie,
I've got an m7 helicoil kit, this would be an easy fix, and if I'd had it (and a drill) with me the wrong side of Basinstoke on Sunday, that's exactly what I would have done. But I don't think they are the most robust solution.
I guess the test case is: if I'm on a euro, which repair is less likely to fail in an alpine pass, all of a sudden £130 for time serts might be a good investment.
So is locking a steel thread in an ally barrel the way to go? How good are time serts?
Warkton Tornado No.1 wrote:Bobs2 wrote:dickie wrote:Why not helicoil?
If wire thread inserts ("Helicoils") are stipulated in the design & fitted to many aerospace components, then they are surely good enough for the likes of the majority of our repairs.
Fitted correctly, they increase the strength of the threaded hole by having some degree of flexibility along their length, rather than the shear 'spot' loads encountered with threaded holes direct into alloy.
Of course, cleanliness is paramount in fitting.
I prefer to repair with Helicoils because, should they fail, they can often be replaced.
The other consideration is that 'wrenching space' is limited around the exhaust fitting so a good, rolled M7 stud is good to have with an M6 extension nut (pennies from Toolstation) tapped through to M7 with cross lock wire holes.
(Obviously, this good practice is what some of us do in the first place to avoid the need for subsequent repair......)
Bobs2 wrote:
Interesting, are you saying that you drill out good threads and helicoil as a preventative measure?
I have used helicoils for many years and know their worth, my question is are time serts better?
I'm also interested to hear if anyone has used an 18mm deep time sert, as I would ideally like to coninue to use extended thread studs, together with extended wire locked nuts.
Dazts1 wrote:I know what your saying about steel into ally. But with a stub removal is not often needed as you remove springs then remove the pipe. So no in and out wearing the ally out. I’ve had 3 different pipes on this cylinder over the years with Allen bolts and it’s not failed yet. Purely down to not often removing the stub.
Users browsing this forum: Baidu [Spider] and 62 guests
