Carb Inlet Manifold Question
Postby parky » Mon Sep 29, 2014 6:39 pm
What if any, is the difference in the positioning of the holes on an inlet manifold used for bolting down on a TV175 Series 3 and a GP 200 ?
parky
Re: Carb Inlet Manifold Question
Postby Adam_Winstone » Mon Sep 29, 2014 6:44 pm
TV175 is the same as the other non-200 models (if we overlook the Lambro barrels that are the odd one out and have the smaller manifold stud spacing!), meaning that you can change a GP150 manifold for a TV175 manifold (same stud spacing) if you want to use the GP's 22mm carb on the 175. You cannot simply bolt a GP200 manifold onto a 175.
Adam
Postby parky » Tue Sep 30, 2014 7:28 pm
Thank you Adam that makes it nice and clear, I will need to get hold of a TV manifold
parky
Users browsing this forum: Google [Bot] and 60 guests
