Extended Exhaust Bracket
Postby Hughieboy » Wed Jun 19, 2019 11:42 pm
Evening All,
Does anyone know if anyone makes an extra long exhaust bracket that would fit a TSR Evo?
I have 8mm of base packing and I have also had to space out the tail can bracket to clear the panels on my Series 2 so the front bracket is now short to the point that there's not enough meat left to drill holes far enough forward, I could do with another 10mm or so in forward length.
A bit of a head scratcher, does anyone make anything or will I need to make something or get it made?
Grateful for any ideas, thanks.
Hughieboy
Re: Extended Exhaust Bracket
Postby Hughieboy » Thu Jun 20, 2019 6:26 pm
Bump...
Nobody else come up against this?
Hughieboy
Postby rossclark » Fri Jun 21, 2019 12:47 am
Not heard of one but don't see why you couldn't cut ounce out of a bit of steel plate.
Postby Hughieboy » Fri Jun 21, 2019 8:13 am
rossclark wrote:Not heard of one but don't see why you couldn't cut ounce out of a bit of steel plate.
Exactly what I’ve decided to do, thanks.
Hughieboy
Users browsing this forum: Baidu [Spider] and 52 guests
