ST90 vs SAE30 gearbox oil
Postby Hughieboy » Fri Jun 14, 2019 5:14 pm
I'm sure this has been answered 1000 times but I can't find it...
I have recently built a small block GT186 motor, my first build and all is running well but the clutch slips a little when you give it the beans. It currently has a Surflex 4 plate clutch that's been in for a few years so I decided to upgrade to a Readspeed 5 plate clutch as they seem to get good reviews.
However, sitting on the side at after 4pm on a Friday (great timing) I currently have a new bottle of ST90 gear oil but Readspeed recommend SAE30. I'm not an oil expert, I guess this is to do with viscosity but of course being the weekend I want to get on with it and I doubt I will buy that in Halfords... plus I have the new bottle of ST90 already purchased, less what went in when the build was finished last week before discovering the clutch slippage.
Can someone more knowledgeable than I tell me whether this is just a recommendation or if it's essential to correct operation? I don't want to mess things up obviously but would prefer not to have to wait another week if it's not essential. Being a bit of a shed numpty spanner twiddler I don't fully understand or appreciate the difference/importance.
Thanks.
Hughieboy
Re: ST90 vs SAE30 gearbox oil
Postby Scooterdude » Fri Jun 14, 2019 5:26 pm
I run a Readspeed 5 plate on ST90 no problem.
Scooterdude
Postby Hughieboy » Fri Jun 14, 2019 5:43 pm
Scooterdude wrote:I run a Readspeed 5 plate on ST90 no problem.
Thanks, you’ve made my day :D . What motor are you running?
Hughieboy
Postby Scooterdude » Fri Jun 14, 2019 6:30 pm
RT 225
Scooterdude
Postby rossclark » Fri Jun 14, 2019 10:03 pm
Same
Postby ToBoldlyGo » Fri Jun 14, 2019 10:33 pm
I'm using Silkolene medium gear oil in a couple of my engines. Works very well. I don't think it's quite so viscous as the ST90 and you can feel the difference without compromising the performance.
ToBoldlyGo
Postby Hughieboy » Fri Jun 14, 2019 11:20 pm
Think I’ll go with the ST90 for a few hundred miles until the kits run in then maybe change to the SAE30.... I can’t just waste it and it’ll need an oil change then anyway...
Hughieboy
Postby Scooterdude » Sat Jun 15, 2019 8:59 am
Hughieboy wrote:Think I’ll go with the ST90 for a few hundred miles until the kits run in then maybe change to the SAE30.... I can’t just waste it and it’ll need an oil change then anyway...
SAE30 is to thin for a Lambretta. Also you will be surprised how thin the ST90 goes once warm.
Scooterdude
Postby Fast n Furious » Sat Jun 15, 2019 8:01 pm
That's because the weight ratings of these 2 oils are at different temperatures.
Postby Scooterdude » Sat Jun 15, 2019 9:14 pm
Yes that’s right.
Scooterdude
Postby Hughieboy » Sat Jun 15, 2019 10:26 pm
Thanks fellas... I’ll stick with the ST90 and see how it goes :P
Hughieboy
Postby Kev Fox » Mon Jun 17, 2019 9:44 pm
I put SAE30 in my Model D which is correct I believe. In a GT186 I would use ST90 as suggested.
Kev Fox
Users browsing this forum: nastro azzurro and 50 guests
