by Andyf » Tue Jun 04, 2019 8:00 pm
I've often grumbled through gritted teeth about my innate ability to buy rubbish engine mounts, I seem to have to change them much too regularly. Is it likely that I may have been a contributor to the problem by over tightening the nuts on the engine bolt thus causing the rubber to handle the rotation instead of the mounts rotating on the bar? If so, how does one know when to stop tightening?
Andyf
by Sticky » Tue Jun 04, 2019 8:21 pm
The rubber is supposed to handle the rotation. Bar cones and centre tubes supposed to be rigid.
Sticky
by Andyf » Tue Jun 04, 2019 8:38 pm
Thank heavens for that, it is my fault then.
Andyf
by HxPaul » Tue Jun 04, 2019 9:32 pm
Make sure you lift the back of the engine onto the shock absorber before tightening the nuts on the engine bar.If you tighten them before you lift the back of the engine the rubber will be rotated and they will ware quickly.
by Sticky » Tue Jun 04, 2019 9:38 pm
HxPaul wrote:Make sure you lift the back of the engine onto the shock absorber before tightening the nuts on the engine bar.If you tighten them before you lift the back of the engine the rubber will be rotated and they will ware quickly.
Good tip that
Sticky
by Andyf » Wed Jun 05, 2019 11:52 am
+1
Andyf
by lam1962brettagg » Thu Jun 06, 2019 7:48 am
I always use chrome plastic car tow hook covers to protect against contaminates ie petrol oil etc. had my mounts in now 15 years. still as good as new.
hope you get em soted
lam1962brettagg
by Toddy » Thu Jun 06, 2019 12:13 pm
lam1962brettagg wrote:I always use chrome plastic car tow hook covers to protect against contaminates ie petrol oil etc. had my mounts in now 15 years. still as good as new.
What sort of mileage per year do you do ?
by nickw » Thu Jun 06, 2019 6:59 pm
I tried these and ended up with chrome flakey bits all over one side of the scooter where the petrol had spoilt the cover. I must remember to find another pair that aren't chrome.
nickw
by lam1962brettagg » Fri Jun 07, 2019 7:54 am
never had chrome flecks coming off at all.
did a few thou miles every year. no probs.
get good quality tow hooks and make sure they fit snuggly and dont move or spin.
lam1962brettagg
by nickw » Fri Jun 07, 2019 12:08 pm
lam1962brettagg wrote:get good quality tow hooks and make sure they fit snuggly and dont move or spin.
That will be my problem. Cheapest from ebay. Gonna order some black one's now, cheers
nickw
by Andyf » Sat Jun 08, 2019 6:00 pm
lam1962brettagg wrote:never had chrome flecks coming off at all.
>1000m!!!! I'm definitely using crap ones. Will buy SIL next time methinks, I've heard they're decent.
Andyf
by gaz_powell » Sun Jun 09, 2019 8:28 am
Before the rake of so called high end and crap unbranded mounts all we had were SIL.
They do the job adequately and have always been my choice in any type of motor. I've used UNI and found them to be good aswell.
They both seem to have the right balance of ride comfort and longevity.
SIL from Scooter Restorations or UNI from AF both about 20quid a pr.
I always use covers on the mounts with open mouth carbs aswell.
Users browsing this forum: Baidu [Spider], Google [Bot], nastro azzurro and 76 guests
