Strange one this
Strange one this
Postby neil64 » Sat May 25, 2019 8:31 am
Hi
I am running a mugelo 186, with a club man , and a delorto phbh26 carb .pretty standard set up these days . Starts fine ,I've jetted as to certain dealers website , pilot 50, atomized av 264, needle x4 ,mid clip . Rides ok up to 3/4 throttle then a slight 4 stroke then has the effect of cutting out . I'm currently at 100 main jet , any suggestions ?. Thanks in advance .
neil64
Re: Strange one this
Postby MickYork » Sat May 25, 2019 8:38 am
Have you checked flow from tap ? Might be running a bit slow, worth checking.
Postby ULC Soulagent » Sat May 25, 2019 11:18 am
Also suggest you check which float bowl needle jet you have in it ;)
ULC Soulagent
Postby neil64 » Sat May 25, 2019 1:23 pm
Currently using metal float bowl with needle x4 - av264 atomiser.cheers
neil64
Postby ULC Soulagent » Sat May 25, 2019 3:01 pm
neil64 wrote:Currently using metal float bowl with needle x4 - av264 atomiser.cheers
No, not the float bowl itself but the float needle jet
ULC Soulagent
Postby neil64 » Tue May 28, 2019 9:51 pm
Ok , its got 2-25 on the side of it ,cheers
neil64
Postby ULC Soulagent » Tue May 28, 2019 11:35 pm
neil64 wrote:Ok , its got 2-25 on the side of it ,cheers
Well that’s ample for a 186 kit
ULC Soulagent
Postby coaster » Wed May 29, 2019 8:01 am
If its consistently cutting out at 3/4 throttle then that would suggest that the main jet is the issue. 100 sounds too small to me, try going up several sizes until it gets boggy above 3/4 and then come back down in stages. That throttle position corresponds to the transition from the needle/atomizer to the main jet.
As already mentioned, fuel flow could be an issue, Have you firstly checked the flow rate from the tap? (you should be using a fast flow tap with a Mugello) If you undo the pipe from the carb and put a bowl under it think you need to flow about 1/2 litre in a minute (check Stickies book).
Postby neil64 » Thu May 30, 2019 4:04 pm
hi , inlight of this issue , and looking at the spec of this carb which should be correct . ive been offered a 28 pwk to try . so im carefully going to try it , have been pointed to a website for jetting spec but ive been advised it should be somewhere near , shall see.
cheers ,
neil64
Postby Bogie » Thu May 30, 2019 7:30 pm
just had a muggy on the dyno today , same set up apart from a gori pipe . 40 slide , Av266 atomiser x7 needle 2nd clip down , 55 pilot and 115 main
Bogie
Postby Rich Oswald » Fri May 31, 2019 12:07 pm
Bogie wrote:just had a muggy on the dyno today , same set up apart from a gori pipe . 40 slide , Av266 atomiser x7 needle 2nd clip down , 55 pilot and 115 main
What CC Mugello? Pilot seems big imo.
Postby Donnie » Fri May 31, 2019 4:23 pm
neil64 wrote:hi , inlight of this issue , and looking at the spec of this carb which should be correct . ive been offered a 28 pwk to try . so im carefully going to try it , have been pointed to a website for jetting spec but ive been advised it should be somewhere near , shall see.
cheers ,
That is a mistake, you really should simply check the flow of the tap then put a 118 main jet in.
Now changing carbs you're going to be jetting completely again and facing a different problem.
Donnie
Postby MickYork » Fri May 31, 2019 6:26 pm
1st post after posting the question suggested checking flow rate, mentioned again by others.......
Postby Bogie » Fri May 31, 2019 8:08 pm
it was a 198 small block , and i always run a big pilot jet on everything . she runs and idles spot on ...
Bogie
Postby dscscotty » Sun Jun 02, 2019 8:32 pm
Try a different float bowl, a friend of mine has experienced issue with an alloy float bowl when changing from a plastic one, not sure of the reason but reckoned it was cured when reverting back to plastic one,
Postby dscscotty » Sun Jun 02, 2019 8:35 pm
Just re- read this-x4 needle??
Postby neil64 » Wed Jun 05, 2019 7:27 pm
yes an x4 , as with cam lam guide.
neil64
Postby dscscotty » Wed Jun 05, 2019 7:53 pm
I'd try another needle, possibly x7,
Postby Toddy » Wed Jun 05, 2019 8:19 pm
dscscotty wrote:I'd try another needle, possibly x7,
+1
Postby Rich Oswald » Wed Jun 05, 2019 10:05 pm
+1
+2
Users browsing this forum: Bing [Bot] and 6 guests
