neil64 wrote:Currently using metal float bowl with needle x4 - av264 atomiser.cheers
neil64 wrote:Ok , its got 2-25 on the side of it ,cheers
Bogie wrote:just had a muggy on the dyno today , same set up apart from a gori pipe . 40 slide , Av266 atomiser x7 needle 2nd clip down , 55 pilot and 115 main
neil64 wrote:hi , inlight of this issue , and looking at the spec of this carb which should be correct . ive been offered a 28 pwk to try . so im carefully going to try it , have been pointed to a website for jetting spec but ive been advised it should be somewhere near , shall see.
cheers ,
Rich Oswald wrote:Bogie wrote:just had a muggy on the dyno today , same set up apart from a gori pipe . 40 slide , Av266 atomiser x7 needle 2nd clip down , 55 pilot and 115 main
What CC Mugello? Pilot seems big imo.
dscscotty wrote:I'd try another needle, possibly x7,
Toddy wrote:dscscotty wrote:I'd try another needle, possibly x7,
+1
Users browsing this forum: Baidu [Spider] and 76 guests
