Bit Stumped?
Bit Stumped?
Postby foremanbob » Mon Jun 03, 2019 9:20 pm
Just built a new engine for a mate RT195... built about 4 of these this year... can I get the bastard to start?
Engine leak tested. 1.2mm squish. 0.5mm plug gap
Got plenty Fuel... Know I've got good compression... I'm getting a good strong spark....
I dont know the heritage of the Stator & Flywheel, never saw the engine running but told it was....
Compression, Fuel & Spark.... should equal bang... but nothing.
Tried easystart... nothing...
Can only be timing right?
Static Timing set at 17deg (positive stop TDC)
foremanbob
Re: Bit Stumped?
Postby Jono » Mon Jun 03, 2019 9:35 pm
Hi mate
Is the engine in the scooter or on test rig.
If in bike is ignition down to Earth? Disconnect ignition kill wire to headset.
Maybe worth a try.
Jono
Jono
Re: Bit Stumped?
Postby MickYork » Mon Jun 03, 2019 9:50 pm
Piston right way round ?
Would be trying another stator, plug, cdi and if desperate a flywheel.....
Re: Bit Stumped?
Postby foremanbob » Mon Jun 03, 2019 10:02 pm
Not green wire from headset... good a good strong spark
Piston fitted correctly
Got a new stator and flywheel for the next build that I’ll try tomorrow night
foremanbob
Re: Bit Stumped?
Postby HxPaul » Tue Jun 04, 2019 8:51 am
foremanbob wrote:Just built a new engine for a mate RT195... built about 4 of these this year... can I get the bastard to start?
If your getting a good spark,all it can be is the timing.
Re: Bit Stumped?
Postby Toddy » Tue Jun 04, 2019 12:13 pm
foremanbob wrote:Not green wire from headset... good a good strong spark
A good strong spark with the plug out does not mean its sparking in the scooter try the green wire out to check
Re: Bit Stumped?
Postby foremanbob » Tue Jun 04, 2019 12:45 pm
Thanks Toddy... only green from stator connected...
foremanbob
Re: Bit Stumped?
Postby coaster » Tue Jun 04, 2019 3:33 pm
Is the plug getting wet?
It might be sparking but is it sparking at the right point? Have you tried a different flywheel?
Re: Bit Stumped?
Postby foremanbob » Tue Jun 04, 2019 7:48 pm
Changed to a new flywheel... no difference...
Changed over the stator... started second kick....
Thanks for your help...
foremanbob
Re: Bit Stumped?
Postby Toddy » Tue Jun 04, 2019 8:15 pm
foremanbob wrote:Changed to a new flywheel... no difference...
Always good to hear a happy ending mate
Re: Bit Stumped?
Postby foremanbob » Tue Jun 04, 2019 8:25 pm
Yeah... you do start to doubt yourself.... everyday a school day with old 2 strokes
foremanbob
Re: Bit Stumped?
Postby Andyf » Wed Jun 05, 2019 9:20 pm
I'm a fully paid-up member of the WKFA Scooter Club so forgive daft question. What wasn't happening?
Andyf
Users browsing this forum: Baidu [Spider] and 52 guests
