Anyone any experience of using these?
Or are they a stay well clear of piston ?
https://rover.ebay.com/rover/0/0/0?mpre ... 2595389485
Norrie Bodge wrote:Anyone any experience of using these?
coaster wrote:I spotted these too and was wondering the same thing, cheap enough to buy as a get you home spare at that price.I was a bit confused by the '1mm chrome wire' rings, I though chrome rings were ironAlso, does anyone know which grade .02 equates too?
dscscotty wrote:I've used them several times, some last some don't, as Gaz stated the rings are crap and are best replaced, I've got a few in the naughty corner minus ring pegs! Just to clarify the rating on the piston as 70.02 which equates to 0.02mm,
Also clarification with regards to piston size grading A,B,C etc, be careful with this as this is often only relevant for the cylinder the piston is designed, e.g. Grade A -Avanti/Ron Moss piston may not be compatible for Grade A TS1 Cylinder, infact I've measured this exact combination with a little over 2 thou clearance, which is to tight!
coaster wrote:dscscotty wrote:I've used them several times, some last some don't, as Gaz stated the rings are crap and are best replaced, I've got a few in the naughty corner minus ring pegs! Just to clarify the rating on the piston as 70.02 which equates to 0.02mm,
Interestingly, I was considering one for my Avanti which has a 69.67mm piston, it has a reed valve piston which has just popped.
Warkton Tornado No.1 wrote:coaster wrote:dscscotty wrote:I've used them several times, some last some don't, as Gaz stated the rings are crap and are best replaced, I've got a few in the naughty corner minus ring pegs! Just to clarify the rating on the piston as 70.02 which equates to 0.02mm,
Currently, I'm rebuilding & tuning a TS1 70 mm bore with a DT250 piston from Grampians. Non Dykes rings, of course. I wanted to try one for ages as an alternative to TS250 pistons.
(Either the Yamaha or Suzuki piston, in genuine or a 'good' pattern form are going to be a safer & better choice IMHO, but the gudgeon pin size needs taking into account, but I've been using the flanged Glacier bushes for years with no issues, which often help with the excess little end side play that may be encountered)
Users browsing this forum: Google [Bot] and 67 guests
