Should I get stuck in or leave it another 4y
Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
Postby Storkfoot » Wed May 15, 2019 8:32 pm
Re: Should I get stuck in or leave it another 4y
Postby coaster » Fri May 17, 2019 7:48 am
Make a start mate, it could always be a slow burn, I wont be starting mine any time soon either. :roll:
Postby mickey c » Sat May 18, 2019 11:27 pm
Good time to get going with the new casa 135 kit in production! Supposed to be quite nippy!
That rear rack is rare thing & would probably buy a few of these new Vega performance goodies!
Saying that, I found mine tricky to build & it’s still not running right!
mickey c
Postby Storkfoot » Sun May 19, 2019 8:50 pm
I am going to keep it standard. The engine casing has been welded up in the past and probably wouldn’t be the best example to put more power through.
The rear rack is a stainless copy of an original. It was badly made and I have just had a mate re-weld it but it’s still not a great fit and will need a bit more work.
I am going to make a start on the engine in the next few weeks, firstly by getting it vapour blasted.
I bought this project over 4 years ago now. It’s mostly all there. I have done precious little on it since. I have the original plate which is down on the DVLA website when it went computerised in ‘83 so, I think, I should be okay to get it re-registered on the original number. We’ll see though.
Postby Storkfoot » Sat Jun 15, 2019 3:29 pm
Just checking legshields fit okay after new struts welded on.
Postby Storkfoot » Wed Sep 04, 2019 10:12 pm
Bodywork on hold but have just made a start on the engine:
Postby Storkfoot » Wed Sep 11, 2019 7:37 pm
Well, having had to machine the lip on the drive side of the crank due to some pitting being evident (this then necessitated a non standard size double lipped seal) I now have the crank in. Had I had a decent front sprocket bolt and the correct sized dished washer for the layshaft, I could have progressed the build further.
But, I didn’t :roll: :)
Postby Storkfoot » Tue Oct 15, 2019 3:29 pm
The moment I realised I had another problem. This time the endplate.
Postby Storkfoot » Tue Oct 15, 2019 7:53 pm
Turns out that my endplate was a Starstream one and not a Vega. That meant I had to take an angle grinder to the underside of the endplate to get first gear to clear the endplate. On the plus side, the endfloat was within tolerance with the only shim I had.
Postby Storkfoot » Sat Oct 19, 2019 10:22 pm
I now realise that there are two types of casing and, therefore, two different sets of chain guides :roll:
Postby mickey c » Tue Oct 22, 2019 6:10 pm
Oh the fun of Luna building! I was also very much in the dark hence why 4 years on its still not quite set up right! I’m sure (hope) we both think it’s worth it the end! I need to, I’ve got a bitsa I’m going to have a go at building in hopefully not too distant future!
mickey c
Postby Storkfoot » Tue Oct 22, 2019 9:49 pm
mickey c wrote:Oh the fun of Luna building! I was also very much in the dark hence why 4 years on its still not quite set up right! I’m sure (hope) we both think it’s worth it the end! I need to, I’ve got a bitsa I’m going to have a go at building in hopefully not too distant future!
Yep, it continues to fight me all the way. Finding a variety of non Vega parts in the box hasn’t helped and neither has my stubbornness to use old parts rather than lash out cash on new ones.
Goodness knows what has happened to the chain (Regina which, I think may have been original). I have never seen one so stretched. Mind you, given that the casing has clearly had a catastrophic accident in the past, I wouldn’t be surprised if this engine (well the bits that are Vega or Cometa) was used for racing or scrambling.
Postby Storkfoot » Sat Nov 09, 2019 7:24 pm
A new chain, LTH chain tensioner and a good hour fettling the clutch:
Postby coaster » Tue Nov 12, 2019 9:33 am
Grear progress Paul, are they new brake and gear linkages or have you had them plated?
Postby Storkfoot » Tue Nov 12, 2019 10:35 am
coaster wrote:Grear progress Paul, are they new brake and gear linkages or have you had them plated?
Plated in yellow passivate. I think the rear brake linkage is actually J range but it fits fine.
Postby coaster » Tue Nov 12, 2019 8:27 pm
Storkfoot wrote:.....Plated in yellow passivate. I think the rear brake linkage is actually J range but it fits fine.
Was that a Frosts diy kit? looks good
Postby Storkfoot » Tue Nov 12, 2019 8:32 pm
No. It was a local platers. The engine bits came out well but the fork links will need doing again eventually.
Postby Storkfoot » Thu Mar 19, 2020 9:45 pm
Engine should be finished in the next few days now I have the top end back from Chiselspeed. It’s moving on at pace now :D
Postby Toddy » Tue Mar 24, 2020 7:15 am
Interesting Thread Paul never been a Lui fan but it certainly looks interesteng , good luck with it and keep posting updates :D
Postby Storkfoot » Tue Mar 24, 2020 9:36 am
Toddy wrote:Interesting Thread Paul never been a Lui fan but it certainly looks interesteng , good luck with it and keep posting updates :D
Cheers, Paul. I suspect that I won’t be seeing the bodywork back from paint anytime soon, give the seriousness of the situation, but I am going to put in a couple of online orders to get as much stuff done as I can.
Return to Luna & J Range
Users browsing this forum: No registered users and 25 guests
