MAXI wrote:Quattrini i've just put onto a Casa case. Now in bike ready for this season
Quatranni 225 by Anthony Maxwell, on Flickr
Any more updates on this guys?
lozmondo wrote:Ive got a Chiselspeed easy clutch and it is brilliant...like a standard P200 clutch
Toddy wrote:lozmondo wrote:Ive got a Chiselspeed easy clutch and it is brilliant...like a standard P200 clutch
What’s a p200![]()
bennn wrote:How's everybody getting on with these long term?
I've just picked a kit up after looking around on here and speaking to various people, couple of questions though - I'm planning on using a SIP 60x116 crank for the extra CC, I'm assuming I'll be needing a 1mm base packer but how do I centralise the bore if I do this as the spigot is only 1mm so none will protrude into the casings?
I've seen a few on here have the 'improved' Chiselspeed inlet rubber, what is to be gained by using one of these?
How have you all reduced the compression ratio on the recessed head, machining the bowl?
Be a while until I build it up as I'm having to get the gasket area built up on my Spanish S2 casing, there's only around 1mm of gasket area at the top of the transfer area.
Many thanks, Ben.
Toddy wrote:Ben if you do faceache join the below loads off info on here
https://www.facebook.com/groups/3888578 ... ?ref=share
Oh yes, 10.7:1 for me.
Hope that helps to start with, highly recommend the FB group though.
Mark
bike grim wrote:Really good. Tried with both clubman and expansion exhaust and it will be a great all rounder
Users browsing this forum: No registered users and 51 guests
