bennn wrote:Afternoon all, hoping for a little bit of advice as I've used the 'search' function and not found what I'm looking for.
I'm just running in my freshly built RB20 kit and I'm struggling to get it to pull in 4th gear, 1,2,3rd all fine but I assume I'm dropping too far out of the power for it to keep going from 3rd to 4th.
I'm running AF 46T Road casette clutch, with either 16t or 17t on the front (can't remember) on Spanish Li125 gearbox. Been told an Indian GP200 gearbox will sort my problem as its a shorter gap between 3rd and 4th - but unsure if I'll need to change front sprocket too?
Thanks for any help in advance, Ben.
bennn wrote:Thanks, would it be OK at 18x46 or not?
Thanks, Ben.
bennn wrote:Thats right Holty I'm using the Chiselspeed ADS Fast Road, I can get it into the power in 4th if its slightly downhill a tailwind or I absoloutely spank it on the flat.
Think I'm just gonna go for the Indian GP200 box (a mate has one) and just change front sprocket to 18T and chain to suit and see what it's like at that, hopefully shouldn't be too costly
